Question about Garden
Brother XL 5020 Can't control foot pedal properly, keeps running away with me, instead of being able to sew slowly stitch by stitch.
I have oiled and cleaned everything.
  • 619 Answers
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
Posted on Feb 22, 2008
  • 166 Answers
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Posted on Jan 02, 2009
  • 36 Answers
SOURCE: Brother XL--2600 Sewing Machine not picking up Stitches at all!
Take the thread out, Take the needle plate out Watch as the needle comes comes down, make sure the hook is just above the eye of the the needle as it makes its pass by the scarf of the needle if not refer to my post on timing.
Posted on Jun 02, 2010
SOURCE: lost my users manual- how
The brother website has free operation manuals
On the home page,, on the left hand side down towards
The bottom look for PRODUCT MANUALS
Click on it & it will take you to another page where you can
Pick your model number & download the manual
Posted on Jan 24, 2011
aeroseek
  • 55 Answers
SOURCE: foot pedal dead, machine keeps sewing!
Sounds like your foot control is faulty.
I can supply foot controls for 99% of sewing machines.
Mike
sewingmachines2004@yahoo.co.uk
http://www.sewingmachineswales.com
Posted on Oct 10, 2012
I took apart my sewing machine, Brother CE1100PRW, to clean, and "Error 1" would not go away, please help.
Brother says:
The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
An E1 message appears on the panel Brother
Apr 13, 2018 | Brother Sewing Machines
I don't know how to change needle postion when changing the foot to another one my machine is a brother xl 3022
Here's a manual for your machine:
Brother XL 3010 Operation Manual
It appears that your machine does not have the ability for the user to change the needle position. Instead, it seems that the selection of the specific stitch pattern determines where the needle is positioned, ie #1 appears to set the needle in the left position but other stitch and width selection will move the needle position.
Oct 16, 2017 | Brother Sewing Machines
I was given a brother cs-8150. The manual says it will operate without foot feed. I tried to use auto sew and machine tells me to change speed controller mode to off. Where do I do that.
Not able to find any online instructions for your machine, so here goes. There may be some confusion as to what foot feed means.
I believe foot feed refers to the feed dogs. When you disable the feed dogs (drop them), then you must manipulate the fabric manually--used mostly for darning or free motion quilting. In essence the feed dogs are no longer moving the fabric for you. Instead, you manually move the fabric and control the speed at which it stitches with your foot control. Perhaps that is why you need to turn off the speed control because you will determine the speed with your foot.
Foot control refers to the foot pedal that you use to control the speed that the machine sews (much like the gas pedal in your car). Some machines have the ability to sew without the use of a foot control unit. To do so, there is usually a button or lever somewhere to start and stop the machine. When activated, the machine will continue to stitch until you stop it.
Hopefully this will help you find a resolution.
Mar 28, 2016 | Brother Sewing Machines
I bought Brother sewing machine Model XL 2230, And could not get a good stitch. Keeps giving me loop either on top stitch or down stitch. Dont know if the single needle can't do straight sewing and dont...
The foot is on the side. Make sure it is clean. Take off the plate and remove the bobbin cleaning all the lint and thread out with q-tips. Oil if needed. Make sure you are using the same thread in the bobbin as on top. Rethread the machine making sure you do it correctly. Change needles using Schmetz as it is shorter and I have found Singer and white label needles are too long and cause problems and well as break easily as they hit the bobbin and cause looping. Not sure what you need to know about the foot. It should have a handle on it so you can put it up or down. Google Brother model XL 2230 and download a manual to find lots of info about your machine.
May 02, 2011 | Brother Sewing Machines
Does the Brother XL-5340 do an overlock stitch? If it does do I need to change the foot and to which foot? Thanks
There is an overedge stitch (page 38) that uses the regular presser foot.
If you do not have a manual, you can download (free) from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5340
Mar 31, 2010 | Brother XL-5340 Mechanical Sewing Machine
Poor stitch on underneath when sewing on material
Re-thread the machine with the presser foot up and see if this improves the stitching.
When a sewing machine is threaded with the foot down, the thread cannot properly enter the tension control and then when you begin to sew, then tension cannot control the flow of thread as it is designed to do.
Refer to the manual and do the routine maintenance as recommended and this will help keep the machine working as it should.
Mar 06, 2010 | Brother XL-2230 Mechanical Sewing Machine
Can not get the brother XL2600i to stitch the top thread does not catch the thread coming out of the bobbin. so it does not stitch
Make sure the needle has been properly installed - flat side to the back of the machine.
Thread the top thread with the presser foot up - always.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Hold onto the thread tail at the needle and lower (by hand and not the power pedal) and raise the needle to pull the bobbin thread to the top of the machine.
Take both thread tails under the presser foot and to the back of the machine before you begin to sew.
Feb 18, 2010 | Brother XL-2600I
A 1968 BROTHER SEWING MACHINE. PROBLEM IS THE FOOT
The carbons in the ceramic tube normally break away, you should not have any problem if you have a new foot control,
Feb 15, 2010 | Sewing Machines
Brother XL-4012
ok,,when you press the foot peddle you will hear a continuous noise like a motor running that means its not the foot peddle, if not peddle is dying or motor carbon brushes are worn, this is a simple fix, we just need to narrow it down
Jan 16, 2008 | Sewing Machines
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
