Which buttons do I press to light pilot lihgtvulcan series
Lennox G10 pilot light is out how do I light it. There is a red button next to the knob that if I press down the knob turns. Help!
Turn knob to pilot press down red button light pilot hold red button down for 45 secs let go of red button turn knob to main flame should light .
Oct 29, 2016 | Heating & Cooling
Pilot light will not ignite water heater
the pilot light serves to purposes. it is the source of ignition for the main burner and is a safety device that detects wether there is a flame or not. if the pilot light stays on when you stop pressing the pilot light button then you need to turn the knob to the on position to light the main burner. the pilot light is not the on position. if the pilot light goes out when you stop pressing the pilot light button then the thermocouple or flame sensor needs replacing. good luck
Nov 30, 2013 | Raypak Pool & Spa
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
I have a Vulcan Gas wall furnace that is not working. We cannot work out how to light the pilot light. According to the documents we have it is a 26.4MJ model or the 40MJ model
The Quazar manual says....
-Thermostat control knob to 0
-Then press and hold down * (Star) button
-The press the "ignition" button one or more times until the pilot lights
CONTINUE to hold the * button for at least 15 seconds and release slowly making sure the pilot stays lighted.
-If the pilot goes out.. repeats steps above and hold the * button for much longer than 15 seconds and THEN release the * button slowly.
Kelly
May 06, 2011 | Heating & Cooling
Best way to relight the pilot without peezo ignition duct heater
You need to hold down the pilot button all the way down (turn selector to pilot).
When pressing the pizo count to 5 then press and repeat. It you just click it constantly you will lose your mind.
Jun 07, 2010 | Dehumidifiers
Pilot lights but won't stay light on release of Pilot button
Replace the thermocouple that the pilot light heats up to keep the gas on.
Jul 07, 2009 | Hayward H-series Electronic Gas Pool...
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Pilot light will not ignite on my bosch 10p water wizard system
This process is best performed at night so you can see the pilot light in action.
Important...*ensure all hot water taps are off*
1) press and hold pilot button (extreme left button)
2) press spark button (extreme right button) while holding in pilot button from step 1
3) with the pilot button still held in, observe the pilot light through the window. if there is no pilot light now, your heater is busted.
4) if you see the pilot light above, very quickly *completely* remove your finger from the pilot button while at the same time pressing in the flame button (second from left - this button will not work until you completely remove your finger form the pilot button so timing is important) - the pilot light should stay lit.
5) if it goes out or your timing is off, repeat these 4 steps until it lights.
This could take a number of tries and can be quite frustrating until you can get the timing of step 4 right. Good Luck!
May 26, 2008 | Video Game Consoles & Games
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
