Question about Vulcan Kitchen Appliances - Others
Vulcan series 37 pilot - Vulcan Kitchen Appliances - Others
Which buttons do use to light the pilot light please
motor cycles do not have pilot lights .SEARCH thru Google
Aug 09, 2017 | Motorcycles
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
I have a vulcan fryer and i can light the pilot then i turned on the flames it came on then went out and would not come back on the pilot stayed lit.
Sounds like thermostat is bad... Vulcan also recommends on replacing the high limit as well.
If you have further questions, call Vulcan directly and they will direct you to a dealer that sells their parts... Their number is 502-778-2791. If I can help in any other way, call me at 888-542-5959, Restaurant Equipment Outlet, Cincinnati, OH and our website is www.restaurantequipmentinc.com
Aug 13, 2011 | Vulcan EF3 Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
I have purchased a house with a Vulcan gas space heater. The pilot light was on but since the gas was temporarily turned off I can not turn on the pilot light. I am in Adelaide South Australia.
you have air in the gas line , the pilot being so small it would take ages to come through , you need to purge the line to get the air out , se if you can undo the pilot line to pruge it
Oct 14, 2010 | Vulcan Heating & Cooling
Can't seem to ignite pilot on a 30 year old vulcan heater. Same problem every year as winter is approaching :) Usually works fine once pilot is on though.
It's probably just a dirty pilot orifice (or a spider web), if it's been off since last winter. Try using a can of compressed air with attached straw (like you use to clean computer keyboards) and blow out the dust from the pilot orifice in the pilot assembly, which is where you light it. That should do the trick. Good luck! Douglas
Jun 07, 2010 | Heating & Cooling
My vulcan burners lit but I can't get the OVEN pilot to light . What are the steps to light the oven ?
use matches,the pilot ligth is hard to replace unless in the tecnician can do,and hard to find the parts.
tnx.gerbee
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
After igniting pilot and allowing gas to continue for 30seconds when i release and turn knob to on position - the pilot goes out - model vulcan cx 130 - 90
sounds like you need a new thermocouple. Its the sensor that sits in the pilot flame and has a copper tube going back to the gas valve. All you need to know to get one is its length. They are cheap and usually found in hardware stores, It sends a signal to the gas valve, telling it that there is a flame once it gets hot.
Jun 13, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Vulcan fryer gas control knob will not turn
700 SERIES GAS VALVE MUST BE CHANGED COMES WITH NEW KNOB PRICE OF GAS VALVE IS ABOUT $105.00
Nov 16, 2008 | Vulcan EF3 Deep Fryer
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Kitchen Appliances - Others Logo
29 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
