Explain what it means if u divide a quantity between two people in these ratios 1:1
    New Friend:
    Problem Solver:
  • 7 Answers
Both parts are equal amounts
Posted on Aug 09, 2017
3 Suggested Answers
  • 291 Answers
SOURCE: Divide 56Kg in the ratio of 4:3
You just need to divide the 56 by 7 in order to get the right base, then multiply that result by 4 and then 3 in order to get the answers. So...
56/7 is 8. 8*4 is 32, and 8*3 is 24.
32Kg and 24Kg
You can do this with algebra as well, equation is 4x + 3x = 56.
Posted on Sep 17, 2009
Testimonial: "Thank you"
geoffw147
  • 1929 Answers
SOURCE: Divide 28 in the ratio of 3:1
28 in a ratio of 3:1 would be 21:7
3:1 is 4 parts total, so 1 part is = 7, so 3:1 is ( 3*7 ) : 7
Posted on Feb 14, 2017
What does 6.8 compression ratio m3an in kpa or psi on a 30d yamaha outboard motor
It means your engine's cylinder volume from the piston being at bottom dead center to top dead center divided by it's compression volume (the volume in just the cylinder head with the piston at TDC) equals 6.8,
which is a very low compression ratio.
It is not a measure of PSI. It's the ratio of how much the gas/air mixture is compressed before ignition.
The engine is taking 6.8 units and compressing it into 1 unit before ignition - a ratio of 6.8 to 1.
Jan 23, 2018 | Yamaha Boating
How many gallons of antifreeze does a 2001 mercury villager hold
1/2 the volume for the cooling system
anti freeze is mixed at the ratio of 50% or 1:1
Nov 02, 2017 | Mercury Cars & Trucks
What is the petrol to 2 stroke oil ratio for the 61
really? grade school math.
Divide 1 by the total number of parts (water + solution). For example, if your mixratio is 8:1 or 8 parts water to 1 part solution, there are (8 + 1) or 9 parts. The mixing percentage is 11.1% (1 divided by 9). If your mix ratio is 4:1 or 4 parts water to 1 part solution, there are (4 + 1) or 5 parts.
Sep 07, 2017 | Garden
Please explain how you do ratios
A ratio can be simplified by dividing both sides of the ratio by the Highest Common Factor (HCF). The highest common factor is the largest number that goes into both numbers of your ratio. In example 1 you are asked to simplify the ratio 6:8. Here the HCF is 2 so divide both sides of the ratio by 2 to give 3:4.
https://www.youtube.com/watch?v=cbjQWf411O8
Mar 04, 2015 | The Learning Company Achieve! Math &...
How can you invent a ratio
It is just one quantity divided by another, eg 2/3 or x/y . Is that what you needed?
Jun 13, 2014 | Computers & Internet
I dont know what a ratio is
A ratio is a division of two quantities that may or may not be of the same nature.
Same nature
You can for example have the ratio of the perimeters of two similar triangles. ratio=perimeter1/perimeter2
Different nature
If an automobilist travels at a constant rate (notice the root RATE, RATIO), the rate of travel is expressed as the ratio of the distance travelled (d) to the time taken to travel the distance. That ratio is called the speed v
v=d/t
Since the ratio involves two quantities of different nature, the speed has a unit derived from the unit of distance and the unit of time; Example v=65 km/h
Other examples:
There is a ratio of 1.45 US $ to 1 Euro. This is usually referred to as the exchange RATE.
The odds of something happening is 7 to 2.
What is really meant when a ratio is involved depends on the context. But what you should remember is that a ratio involves the division of two quantities.
Proportions: The equality of two ratios is called a proprtion.
Feb 08, 2012 | Office Equipment & Supplies
Explain 1 divided by 0
In mathematics, a division is called a division by zero if the divisor is zero. Such a division can be formally expressed as a / 0 where a is the dividend. Whether this expression can be assigned a well-defined value depends upon the mathematical setting. In ordinary (real number) arithmetic, the expression has no meaning, as there is no number which, multiplied by 0, gives a (a?0).
In computer programming, an attempt to divide by zero may, depending on the programming language, generate an error message or may result in a special not-a-number value (see below).
Historically, one of the earliest recorded references to the mathematical impossibility of assigning a value to a / 0 is contained in George Berkeley's criticism of infinitesimal calculus in The Analyst; see Ghosts of departed quantities.
Sep 03, 2010 | Computers & Internet
Red lighting bolt light is on in my 06 dodge charger what does it mean
Divide the smallest number by itself to get 1. Then divide the larger number by the smaller. ie 19 teeth on pinion, 74 on crownwheel will give you a final drive ratio of (74:19) 3.89:1
Jul 11, 2010 | Cars & Trucks
How to calculate ratio number
Ratios are usually written as xx/1 such as 8 to 1 or 4 to 1 so that one is the base number. If you have 8 black sheep out of 64 then it's ration is 64/8 but you want to reduce the 8 to 1 so divide 8 by 8=1. now you have to do the same thing to the the other side of the equation so you have to divide 64 by 8 = 8 or to simplify this divide the first number by the last = the radio. Thus 64/8 = 8/1 on a more difficult scale let's do 6888/123 is 6888 divided by 123 or 56 to 1
Dec 07, 2009 | Computers & Internet
What is the gear ratio difference between 54 teeth cog and a 32 teeth gear cog
More information is needed to answer your question. Is the 54 or 32 tooth gear the input or output gear.
Grat ratio is input divided into output.
32 divided by 10 is a 3.2 to 1 ratio.
54 divided by 10 is a 5.4 to 1 ratio.
Oct 06, 2009 | 1983 Ford Escort Gt
Computers & Internet Logo
David Payne
David Payne
