Question about Ricoh Office Equipment & Supplies
Error code 20254 on Ricoh SG 2100N printer help needed!!
I turn my printer on it starts warming up after a few minutes the red light comes on with error code 20254 and says turn off and back on been doing this for days now also it does kick into life eventually after a lot of turning off and on help needed to identify this code as I can not find it anywhere
SOURCE: Error Code
HAD SAME PROB I WORK FOR RICOH DIRECT SERVICE 670 IS ENGINE CONTROL BOARD OK....
Posted on Oct 07, 2007
fer_nan_14
  • 76 Answers
SOURCE: Canon Hardware Error 03130031-2F26
hi
2F26 is a carriage error,you can solve your problem if you update your firmware version to 1.35
if your printer firmware is 1.32 and below. try this link http://software.canon-europe.com/software/0027485.asp?model= follow the instruction included
Posted on Nov 26, 2008
SOURCE: Error Code SC 120
You need a tech...here is the description of your "SC":
The scanner home position sensor
does not detect the scanner leaving
the home position.
Here are the possible solutions:
- Defective scanner home
position sensor
- Defective scanner drive motor
position sensor connector
connector
- Defective BICU board
Posted on Mar 12, 2009
  • 3230 Answers
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
  • 11 Answers
SOURCE: Red light blinking and printer error "check printer ##330" appear
## 330 Power Supply (Replace/Repair)
Replacement part number is HH3-5278
Posted on Jul 02, 2010
Sc 558 error code on Ricoh Pro C720
That is an oil supply pump error for the fuser. It probably needs to be replaced.
Jan 29, 2015 | Ricoh Office Equipment & Supplies
57000 error
hi
please my SG 3110DN printer came up with this error code : SC 57000
Jan 06, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Error sc542 service
SC 542 Fusing temperature warm up error.Fusing lamp defective,poor fusing unit connector,thermistor warped or broken,thermostat has tripped,power supply defective.After verify the componenets try reset the error.Enter in service mode:Press the yellow key and press 107 and keep pressed the stop key 3 second.Touch the SP window on screen open the front door and turn OFF the copier.Wait 1 minutes ,close the front door and turn ON the copier.If the error code persist change the upper fuser roller and the thermistors.
Jan 01, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc (28112) error
I have a ricoh SG 3110 DN error code 28112. Can I fix this?
Dec 07, 2013 | Ricoh Aficio Sg 3110Dnw 29Ppm
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Ricoh SG 3110dn, SC 20200
you need change ink collector unit.
Sep 16, 2013 | Ricoh Office Equipment & Supplies
Whats error code sc 28212
Turn off printer remove carts wait 2 minutes but back in and turn on!
Oct 30, 2012 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
I have a Ricoh copier 1022. It is down. it shows SG 546. Immediately I display 107 by pressing the yellow button for a while. The unit marched for a few minutes and then it displays the same error message...
Unstable fusing temperature
Symptom:
The fusing temperature varies 50°C or
more within 1 second twice
continuously.
Possible Cause:
• Thermistor defective
• Poor connection of the fusing unit
• Power supply unit defective
Oct 20, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
Apr 21, 2009 | Office Equipment & Supplies
150 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
