I have recently had fitted a ROCA toilet, when cleaning the inside of the pan I noticed that it wasn't glazed all the way down to the bottom only to just below the water line, is this normal?
The model is the latest rimless, wall hung unit.
  • 236 Answers
SOURCE: GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Posted on Jun 11, 2007
  • 19 Answers
SOURCE: Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Posted on Jan 21, 2010
localwonder
  • 6784 Answers
SOURCE: TOP MOUNT FRIDGE WATER LEAKING INSIDE OF UNIT UNIT
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re tightening the screws.
Posted on Mar 22, 2010
marka19
  • 1430 Answers
SOURCE: Refrigerator has water dripping inside the unit down the back
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Posted on Apr 19, 2010
  • 159 Answers
SOURCE: i have a roca dama toilet seat which needs
Don't know about a roco dama, but most have color coded plugs where the screws go in, you will need to look alittle harder.
Posted on May 08, 2010
There is a leak at the FOOT of my valsir toilet onto the floor what do I do ?
You are going to have to do some investigations...
It could be any of these..
#1 Pan to waste pipe connection
#2 Water flush to pan connection
#3 Cistern to water flush connection
#4 Cold water connection
#5 Cistern overflowing
#6 Condensation
If the cold water valve/washer is faulty then the constant flow of cold water is going to create a lot of condensation.
If the leak only appears after you have flushed the toilet then it is likely to be #1, #2 or #3
Just a matter of elimination..
Apr 22, 2017 | Home
Why doesn't fill valve in toilet drop down after flushing
Likely corroded or warn out. In most cases replace the fill valve. I prefer Lavelle replacement fill valves. If toilet is an old 3.5 gallon or higher model or an early water saver, consider replacing the toilet with a latest generation name brand 1.6 or 1.28 flush model with a glazed trapway.
Oct 31, 2014 | Plumbing
Young child keeps putting things down the toilet - is there a divice that can be fitted to toilet when not in use to catch these things?
I can\'t think of any device that would stop the match box while still letting the poop through. There are child-prof latches which can be installed on the lid. Although this is inconvenient, it is the only workable solution.
Dec 08, 2013 | West Brass Plumbing
Cadet 3 toilet smells like pee - NOT a SEWER smell, a urine smell. It's a brand new toilet, installed by our contractor. There's a brand new extra thick wax ring too. The room smells like urine when nobody...
If your contractor supplied the toilet, then it is his/her problem, not yours. If you supplied the toilet, then: take a mirror and examine under the lip of the bowl. How does the glazing look? Are there areas without glaze? If so, these bare areas are a breeding ground for bad odors. You can try a thorough cleaning both inside the bowl and around the outside of the toilet with an amonia cleaning product. If you use amonia, DO NOT use bleach: the two combined create a deadly gas. Whatever you do, do not hang a bleach based product inside the tank: the bleach will eat away at anything rubber inside the tank. There is a bleach product that hangs inside the tank and disperses the bleach directly into the tube that leads to the toilet bowl. This would be OK.
Aug 12, 2013 | American Standard 4021 White Cadet 3...
How to fit replacements roca soft close hinges on a toilet
These hinges are completely replaceable and I sell them. Here is a step-by step manual how to do it yourself:
http://roca-parts.eu/roca-softclose-repair/
Sep 24, 2011 | Home
I have a six year old roca sink that has developed hairline cracks around the waste outlet ,1 can they be fixed? or is it a fault with the sink glazing ?2 what do i do?????
unfortunately the glazing will have to be re-done,check your gaurantee,some companys not all sometimes give you extended warranties
Jul 20, 2011 | RTO Home
Tank won't stop filling up...overflow hose just keeps running. i lift up on blue piece and it stops, but starts again once i let go. i just got this toilet in the summer...hard to believe it has problems...
You need to replace tank valve.
See photo of the product:
http://salestores.com/fluidmas.html
Buy this product at hardware store.
Turn off water to toilet.
Flush toilet to empty water from tank.
Under the tank, the tank valve is held with two nuts.
Nut1 seals water line to the valve.
Nut2 seals valve to the tank.
Loosen nut1 and it drops down. You can use same nut for new valve, or use new one that comes with product.
Notice there is a beveled washer stuck in bottom of valve, or stuck inside nut1. Your new valve will have a new beveled washer.
Loosen nut2 and valve come loose and can be lifted out.
When you lift up valve, remaining water will run onto floor so have a pan and towel ready.
Notice on bottom of valve is a rubber washer. This washer seals the valve and tank together so water will not leak.
New valve comes with 2 washers > big one and small one. They are usually attached together, small one inside bigger one, and you have to tear them apart.
Clean opening of sand and dirt.
Supply pipe is sticking up.
Put nut1 and small beveled washer onto the supply pipe, with flat side of washer facing downward and rounded side facing up toward tank.
Put bigger washer on bottom of new valve. Flat part of washer goes to valve, beveled part of washer faces downward to tank.
Set valve in place and notice how washer covers the hole.
Put nut2 on bottom of valve and tighten. As you tighten the nut, valve will rotate inside tank. Make sure float and parts can move freely.
The valve doesn't have to be super tight to seal. Just tighten ia reasonable amount, and you can tighten more later if needed.
Now attach nut1 to bottom of new valve and this will seal supply line going into tank.
This nut has to be fairly tight.
Turn water on.
Valve has adjustments for selecting height of water inside tank.
Use paper towel on bottom of valve to check for leaks.
Leave catch pan under new valve for couple days to make sure there is no dripping.
If water is seeping, then tighten nut1 or nut2 a bit more.
Sometimes the shut off start leaking. Open shut off all the way to see if this solves problem.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet.
Jan 10, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
