Question about Blade Saws
Change blade on ozito cms- 210 mitre saw - Blade Saws
  • Blade Master
  • 1,890 Answers
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
Editor925
  • 285 Answers
SOURCE: How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
FixYaSteve
  • 57 Answers
SOURCE: how do i change the blade on my delta 10
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Posted on Jun 14, 2010
SOURCE: Changing the blade on a power mitre saw
http://www.superiorairco.com/cgi-bin/workshop.pl
Posted on Jul 20, 2010
puertobori
  • 7733 Answers
SOURCE: blade guard for Ryobi 254mm Slide Compound Mitre
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
I have a Macalister mitre saw with a 210 dia blade with 30mm bore and 24 teeth need a finer cutting blade just wondered why dia of blade I can get in . its 1400w cod211lsm machine
I am not sure.
205 and 210 mm blades are the modern equivalent of the 8" blade. I too wanted a finer cut blade in my mitre saw. I had stock of a couple of 8 inch blades but when trying to fit them I found a 205 went in but a 210 wouldn't. I preferred the 210 so I had to modify the guard a little.
As your blade is already 210 mm you probably won't have any problems with an 8 inch blade or either of the metric equivalents, though it is unlikely a larger blade will fit, if you can find one. The blade designed for cutting laminate provides just about the finest cut.
Apr 25, 2018 | Blade Saws
Can you advise me where to purchase a dust bag for ozito compound mitre saw.
Part 108
http://cdn3.blocksassets.com/assets/ozito/ozito-product-manuals/b5ZLP0doHsVMmPH/SCMS-107-Spare-Parts.pdf
[PDF]SPARE PARTS cdn3.blocksassets.com/assets/ozito/ozito-product.../SCMS-107-Spare-Parts.pdf
  1. Cached
  2. Similar
SPARE PARTS. SCMS-107. Tool: 8" Slide Compound Mitre Saw. Model No. SCMS-017. Item. No. Description. Part No. How To Order. 13. 20. 35. 52. 58. 63. 66. 67. 74. 91. 92. 96. 108. 109. 116. 126. 132. Mitre Lock Handle. Kerf Board. Bevel Lock Handle Assy. Fence. Material Clamp. Blade Bolt L/H M8x16. Locating ...
[PDF]SPARE PARTS
cdn3.blocksassets.com/assets/ozito/ozito-product.../OZSCMS1600WA-Spare-Parts.pdf
  1. Cached
  2. Similar
SPARE PARTS. OZSCMS1600WA. Tool: 10" Slide Compound Mitre Saw. Model No. OZSCMS1600WA. Item. No. Description. Part No. How To Order. 3. 10. 21. 25. 34. 75. 76. 78. 79. 87. 99. 146. 122. 125. 128 ... The following is a list of spare parts carried by Ozito. Please contact Customer Service for any parts not listed. 4.
[PDF]SPARE PARTS
cdn2.blocksassets.com/assets/ozito/ozito-product-manuals/.../CMS-210-Spare-Parts.pd...
  1. Cached
  2. Similar
SPARE PARTS. CMS-210. Tool: Compound Mitre Saw. Model No. CMS-210. Item. No. Description. Part No. How To Order. 15. 32. 41. 48. 49. 74. 75. 86. 89. 96. 99. 106. 108. 125. Kerf Board. Handwheel Bevel Adj. ... Special Orders Desk at any Bunnings Warehouse. If you have any further questions, please contact Ozito.
Ozito - Customer Service and Support
https://ozito.com.au/service-support/
  1. Cached
  2. Similar
If you need spare parts, manuals or any customer service for your tools we're here to help. Check out all the info you need or contact us.
ozito compound mitre saw spare parts Google Search
Dec 27, 2017 | Saws
How do I change blades on ozito 210mm compound saw
hopefully this manual helps.
There are pictures and instructions on changing the blade, starting on page 15.
http://cdn0.blocksassets.com/assets/ozito/ozito-product-manuals/VFIW5zKsTiAxHGZ/CMS-210.pdf
Oct 27, 2017 | Saws
Where can i get a replacement switch for a ozito mitre saw
from ozito spares or service agent
Aug 26, 2017 | Saws
I need an Ozito Mitre saw 210 mm bolt.ref #63
try the manufacturer's website . we sell nothing here on FIXYA
Jan 26, 2017 | Saws
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
Saws Logo
63 people viewed this question
Top Blade Saws Experts
bozarthm
Level 1 Expert
Wayne Johnson
Are you a Blade Saw Expert? Answer questions, earn points and help others
