Question about Rinnai Heating & Cooling
I have a rinnai geph 2200w pew panel heater. it has been operating as normal, but last night it would not heat as usual. I tried resetting and re-programming it but to no avail. can anyone help
  • 1,202 Answers
It likely needs maintenance.
Posted on Aug 09, 2017
Testimonial: "what kind of maintenance are we talking about. will I have to take to a repair shop? thanks for your help."
  • Thomas Woodburn
    Thomas Woodburn Aug 09, 2017
    It likely needs a good cleaning. This is where I would start. They have so many safety devices that will stop them from running. If you can do it, do it.
  • Anonymous Aug 10, 2017
    thanks so much for your comment. I will contact a repairmen. can anyone recommend a rinnai repairman. I live in Brisbane.
SOURCE: Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Posted on May 26, 2008
SOURCE: my rinnai 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Posted on Dec 22, 2008
  • 12 Answers
SOURCE: Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Posted on Sep 14, 2009
mnwarfield10
  • 452 Answers
SOURCE: My built in Tecnik dishwasher is not heating the
you really need to change or check heating element assy....
Posted on Dec 30, 2009
alicantecoli
  • 22156 Answers
SOURCE: Hi, I have a Nobo electrical
take the panel out pick up the feed cables ,then hot wire them direct to the feed via the thermostat so it works as a conventional heater .its these made in china chips ,useless
Posted on Jan 08, 2011
I have a Rinnai RL 175 Tankless water heater. I just moved into the house two weeks ago. We have no hot water. Green priority light and beeping sound came on. Breaker also flipped on panel. Any ideas?
Usually, Breaker tripping indicates a hard short ... probably the heating element is shorted and needs replacement. Possible bad C/B but don't think so.
Good Luck! handy Henry.
Feb 14, 2017 | Rinnai Water Heaters
I have a 30000 btu rinnai floor heater mod 630530. The pilot wont stay lit . I have installed a new thermo couple . please help
be sure the thermocouple is in the pilot's flame and hold down the pilot lighting button long enough to heat it before trying to operate the heater...20 to 30 seconds should be enough. If this doesn't work, you may have a bad gas valve
Feb 21, 2015 | Rinnai Heating & Cooling
I have an Rinnai Avenger 25TR heater. The problem is that the heater ignites, it starts, but then it turns off. A red light then flashes and the number 13 also flashes in the bottom right hand corner of...
Paul, the Error Code Fault 13, indicates a Combustion Control Fault. This could mean, not enough gas for safe combustion or to much gas for continued operation. In any event, if requires a service call from an authorized Rinnai Service Technician to solve.
Just in case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/CI_Avenger_Blaze_Dynamo_Enduro.pdf
Hope this helped you.
Jul 18, 2011 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
RHFE-556WTA-N After a power failure the heater came on full when power came back on. With the temp setting to L it will not shut off. There is a dehumidifier plugged into the same outlet and it is...
When a power outage occurs while the heat mode is operating the heater had no chance to rid the residual heat that the temperature or time delay takes care of in a normal heat cycle that is satisfied, the safetys that trip are not automatically reset but are manually reset and look like this picture, there can be others in series with this one too try following the circuit some are on the blower wheel the flue and burner areas. rhfe-556wta-n-after-power-cp4yufdp500qfugpjpa1ch44-2-0.jpg
Jun 03, 2011 | Rinnai Heating & Cooling
Is there any possibility my Rinnai econoheat850 gas heater can give off carbon monoxide?
Any time there is combustion of any type fuel, from a Rinnai heater to a car engine. There is always a small amount of Carbon Monoxide given off. But, it's usually in small insignificant amounts.
Since your model is a Vent-free or flue-less model, the chances are a little higher. This usually occurs if the heater has not been properly and regularly maintained. Keep in mind, flue-less heaters take in household air for combustion, heat it and send it back out. Whatever is floating in the household air (duct, lint, pet hair, etc) is pulled into the heater. These things can clog the burner(s), the pilot and the Oxygen Depletion Sensor (ODS) and cause incomplete combustion. Which translates into higher than normal Co levels. However, your unit is equipped with an ODS, that will shut the gas off to the heater, if the household oxygen level reaches 25%. Which is not the danger level, which is 19%. Once the Oxygen level returns to 30%, the ODS will release the gas valve and gas will return to the pilot, so that you can relight it.
When properly maintained and operated according to the Owners Manual (see link below) they are totally safe. In the last 20 years, millions of vent-free/flue-less heaters have been sold and operated throughout the world. There has never been a death related to their use.
Certainly, if you or your family think you are experiencing signs of carbon monoxide poisoning, stop using the heater and have a qualified Rinnai technician check and service the heater. If you have other gas appliances in the house, it may be one of them causing the symptoms and not the heater. You may want to have those check and serviced, too.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Cosyglow&Econoheat.pdf
I hope I was able to help you. Please let me know. Thanks.
May 11, 2011 | Rinnai Heating & Cooling
My Rinnai is too noisy, attached to sheet rock garage wall but other side is a bedroom. Grandaughter is afraid to sleep in that bedroom. Rinnai rep says the noise is normal....
is this a rinnai water heater if so the noise likely is normal it is from the enormous amount of fuel that is being burned to heat water quick enough to get hot water to your faucet.
Sep 12, 2009 | Rinnai Toyostove Direct Vent Heater:...
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Avenger 25TR Model Gas Heater
I just fixed this problem for my parents. All you have to do is hold the up and down arrows that sorround the power buttom for 3 seconds at the same time and the key symbol should dissapear and make a slight beep. Then you should be able to use the heater as normal =]
May 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Nov 10, 2007 | Rinnai EnergySaver 556 Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
