Question about Simpson Washing Machines
Hi have a Simpson front loader and my daughter stopped during washing circle and door lock and end circle stay on.
  • 1554 Answers
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
Posted on Apr 16, 2008
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
SOURCE: I have a simpson swf 1076 front loader washer that
Have the same model
Posted on Sep 08, 2010
  • 1998 Answers
SOURCE: My LG WD-8023 Fb front loader has the door locked
look down the very bottom of the machine you should see a couple screws on the bottom unscrew these and remve the lower panel you may have one screw also in the clean out you will be looking for a type of pull cord that is attached to the door pull the cord and the door will open. if the delay lock is not releasing then you would have to replace the door lock assembly in the unit if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Posted on Mar 15, 2011
  • 6277 Answers
SOURCE: Problem DWD-WD1132 front washing loader stopped
Sorry- we can only deal through the forum unless you take the option to pay for someone to talk to you ;-0(
In any case I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 08, 2011
Testimonial: "Thank you for your comments and help I opened a drain below on the left side of the machine. Water was drained out the machine Then it works normal. "
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
Simpson ezi loader 5.5kg front loader. when it goes to start the door clicks 3 times then the end light flashes. I am an electrician. but I do not work on appliances. if you could send me a...
the door is clicking because it is trying to lock the door but is unable to for some reason what is the make/ model number of the machine? most likely it would be something dealing with the door look but id rather be 100 percent correct then assuming Please send model number i await your reply Thanks again
Dec 09, 2010 | Washing Machines
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Dec 21, 2009 | Washing Machines
Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Jul 06, 2009 | Washing Machines
Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Jun 22, 2009 | Washing Machines
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
