Question about Locks & Locksmithing
I have locked the safe before closing it. How do reset
When I close the safe it doesnt stay locked when i close the door
heres a copy of the manual for this safe , but if it wont lock back its probably telling you the battery's are low
Jan 08, 2016 | Paragon Lock & Safe SureDrop 7875 Digital...
Change code
If it is locked and the person you got it from didn't give you the existing code, you can't. We see this all the time. If there was a way to bypass the code to the safe, anyone could do it. They are called a 'safe' for a reason, the contents are safe once the door is closed and locked :-) The only way to get in is to take to a locksmith who will drill the door, open it and put a new door on it. This is not usually a cost effective open with a small locker type safe.
Nov 23, 2015 | Home Security
How do I close my safe?
call the manufacturer,if you have problems closing it,then you will have problems openning it
Jul 26, 2015 | Locks & Locksmithing
The safe i have is locked with the door open. How do i reset the safe to close the door.
Remove the batteries end leave it for 10mins or so..then replace batteries and set a new combination on the lock.
Feb 24, 2015 | Sentry FIRE-SAFE Combination Safe DS3431,...
How to reset the entry code to homcom 12"x14"x10"
Most of these Chinese safes have a reset button inside the safe. Open the safe, press reset and enter your new combination. Then check it before closing and locking the safe.
Jul 12, 2014 | Safe International Digital Electronic Safe...
How to change the code on my gordon digital electronic safe
Most inexpensive electronic safes have a reset button inside. Push that and then enter the new combination and finally press the button you normally use to unlock. Confirm the new combination works before closing the door again.
Jul 04, 2014 | Safe International Digital Electronic Safe...
How do i change the code on a s25e digital safe i cant find the book
if its like my old woolworths one, open the door and press a red reset button on the inside of the door, close the door and dont lock, put in the 4 numbers u wish a press a A button on the keypad, or whatever ur enter button is, then lock it, then press the 4 numbers again and the A button or enter, a light should stay on and unlock :)
Feb 21, 2011 | Safe International Electronic Gun Safe...
Locks & Locksmithing Logo
214 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
