Question about Smeg Refrigerators
How do I change the mid hinge on a smeg fab 32 fridge freezer
4 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: I have a 2 year
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Posted on Apr 14, 2008
SOURCE: Smeg Fab 32 door problem
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
Posted on Dec 13, 2009
  • 186 Answers
SOURCE: what s the switches inside fridge
prob green power yellow or orange fast freeze
Posted on Aug 13, 2012
What s the switches inside fridge
Aug 12, 2012 | Smeg FAB32 Bottom Freezer Refrigerator
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not instructions
remove the top of the fridge by removing the two screws on the back of the top and sliding the top to the back. that gives you access to the doorhinges. remove the three screews of the lower hinge, which allows you to remove the door from the upper hinge too. (sorry, non native speaker)
Oct 05, 2009 | Smeg FAB28
Smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
Jul 11, 2009 | Smeg FC40RX Bottom Freezer Refrigerator
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Top hinge has just broken off my smeg fridge.
found an old smeg at the local junk yard and took of the hinges and other parts... cheapest way.
Mar 16, 2009 | Smeg FAB28NE6 Refrigerator With Ice Box
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Jul 04, 2008 | Smeg FAB28
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
Apr 14, 2008 | Refrigerators
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
