Question about Plumbing
Need a manual for a Pfister Jaida F-042-JDCC faucet
  • 18 Answers
SOURCE: I have two brand new Price Pfister 042-VGCC
MOST LIKELY YOU HAVE A CLOG AT THE SEAT ON THE INSIDE OF THE FAUCET, TYPICALLY SAND, PEBBLES, OR PIPE SEALANT. TURN THE WATER OFF, UN-SCREW THE HANDLE, REMOVE THE SET SCREW LOCATED INSIDE THE HANDLE BODY, PULL THE HANDLE BODY UP, LOOSEN THE NUT, REMOVE THE SEATS AND STEM AND UN-CLOG THEM.
Posted on Dec 29, 2009
mkh5094
  • 145 Answers
SOURCE: i cant get the price pfister faucet out of kitchen...
There are several nuts on a faucet but I'm assuming you mean the plastic nuts that hold the faucet to the sink. They many times do jam up. To get them off you need to use a large flat head screw driver and a hammer and chisel them off. Chisel from the outside edge in toward the threads on two different sides.
Posted on May 23, 2010
  • 67 Answers
SOURCE: I need an installtion book or pamplet for a PRICE
To find install manuals for Prive PFister go to http://www.pricepfister.com/bath/bath_product_documentation.aspx.
You will need to know either the model number or the collection name of your fixture.
Posted on Aug 03, 2010
  • 25 Answers
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
Turning the water off, letting it drain from pipes, then turning it back on can cause debris inside the pipes to loosen and clog your aerator or flow constrictor in the faucet.
Or your new faucet could have an aggressive flow restrictor. You can sometime remove the restrictor or use a drill to increase the size of the hole if its a simple plastic washer.
Posted on May 05, 2012
  • 7 Answers
SOURCE: Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Posted on Oct 17, 2012
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
Hot water side of a 42 ashfield faucet allows very little water flow. I think it is stopped up, It stop when I change a hot water heater
You will need to take the faucet apart and clean it out. If the faucet is a few years old I would just replace the cartridges and be done with it.
When the water heater was replaced the lime build up in the piping was dislodged and I bet the faucet you are having a problem with was the first faucet used after the new water heater was installed.
Mar 04, 2011 | Price Pfister 042-YP0E Ashfield Single...
Need manual to solve problem need instructions to
Call price Pfister 1-800-PFaucet
They got excellent customer service.
Sep 02, 2010 | Price Pfister Marielle Kitchen Faucet with...
Water not coming through faucet - does come through side spray
First check the aerator at the tip of the faucet where water comes out. Unscrew to check for blockage. If water still does not run, most likely a problem in the body of the faucet. Is faucet still under warranty? If you try taking the faucet apart remember to turn off the water supply lines at the angle/strait stops under the sink. Recommend replacing faucet.
Mar 16, 2010 | Price Pfister 042-HAK Amherst Single...
I have two brand new Price Pfister 042-VGCC faucets and the cold water side comes out really slow. All other fuacets work great and hot water is fine. I disconnected at the valve under the sinks and there...
Dec 15, 2009 | Price Pfister 042-VGCC Polished Chrome...
Need manual for Price Pfister Catalina 548-EOBK. Where Do I find
Just kept checking other websites until I found the manual I needed.
Nov 22, 2008 | Price Pfister 548E0BK Catalina...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
