Question about Ovens
Fan starts clinking as if it's touching something when the fan oven heats up
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
SOURCE: Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Posted on Aug 18, 2007
hongster
  • 6 Answers
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
SOURCE: Noisy Oven when heating up & fan spinning
i have a b600 oven and we've replaced the element but it's still not working can you help biskittin@hotmail.co.uk
Posted on Feb 02, 2009
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
It is making a loud noise as if it is catching onto something it comes and goes sometimes louder than first time it started
I'm guessing your problem is the fan in the oven. To fix: 1. with oven cold, remove back wall fan cover in oven. 2. remove fan. 3. clean and lubricate. 4. install fan. 5. install fan cover making sure fan is not touching. If cover does touch fan, gently bend cover away from fan and install.
May 15, 2016 | Ovens
The fan start coming on after the oven is heated up then f10 starts flashing and the oven starts beeping on my kenmore elite convection oven
the only codes ifind for the f 10 is defective touch pad.. ck the glass alligament /ribbonconnector / replace touch pad if necessary / . this may be a thermadore buit unit / there f10 states also to replace the contr board .. hope this helped **** ..
Dec 04, 2009 | Kenmore 47783 Electric Single Oven
Rubbing sound-like noise when switching bottom oven on
most likly the fault is the fan blades touching the side of the circular hole,to test.1.switch of all power.2.when power is switched of try switching your oven to on position.if oven will not work then proceed3.if you can turn the fan blades by useing a thin piece of wood or simler.4 if when you turn the blades you hear a rubbing noise you might take a closer look if you have torch point it in if you see the blades touching or one of the blades touching it might be possable to to push the offending blade back very slightley useing the same piece of wood you yoused at 3.if this fails to solve your problem the fan moter might be ready to give up. I hope this can solve your problem.yours adrian.
Feb 14, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Fan stopped working
If it is heating without the fan working, then there is probably something wrong with the fan.
If there is no heat as well as the fan not working, then check that the timer is set to manual and not on auto.
To access the fan and heater, remove the rear panel inside the oven, spin the fan by hand,it should be completely free,
If it is not, then it needs replacing.
Plz rate my solution.
Thanks
Jan 02, 2009 | Belling XOU252 Electric Single Oven
Baumatic oven not heating up
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
DamienPJennings@aol.com hope this helps
Jan 13, 2008 | Ovens
Neth, Im not familiar with this oven but I thing someone is handing you a line. I've been doing this for 30 years now and never saw a oven cavity arch when heating. The fact is that there is something wrong with the fan motor or fan blades itself. Call this cat back and have them honor your warranty...Catriver..post back.
Sep 12, 2006 | Baumatic B180 Electric Single Oven
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
