Question about Hotpoint Ovens
Fan clinking on Hotpoint fan oven after it ha warmed up
  • 41 Answers
SOURCE: hotpoint dy46 x oven
Usually with ovens not heating up the element has gone and needs replacing. A few checks to do before going to the expense and trouble of replacing are to check the House Power Box Fuses to make sure none a blown - especially look for the one relating to the Oven or Range. If blown replace the fuse wire. If it blows again you have a problem with the power point or appliance. Does the Oven Fan work? If so chances are the oven is getting power as is the element and your house electrical lines to the Oven are fine and the element needs replacing. Not knowing the particular Brand you have amkes it difficult say how to remove the element. Some elements are accessible from inside the oven - others you have to remove the oven and get access from behind by removing a panel. Whatever you do if you do decide to remove the element MAKE SURE you TURN OFF THE POWER to the Oven. Hope this helps.
Regards
Bryan
Posted on Feb 24, 2008
  • 200 Answers
SOURCE: Fan rattling in Hotpoint BS41 oven
Hi
Check this link
http://repair2000.com/oven.html
Posted on Sep 16, 2008
barkencoa
  • 3463 Answers
SOURCE: Manual
You can download the instructions you require by going to the Hotpoint web site.
In your browser bar type in --hotpoint user manuals
In the list click on---manuals-user guides-handbooks
In the search box enter the oven model number and download as req'd
Plz rate my solution.
Thanks.
Posted on Jan 26, 2009
arepairman
  • 20 Answers
SOURCE: hotpoint sy36x grill element works fine but when
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Posted on Mar 14, 2010
barkencoa
  • 3463 Answers
SOURCE: The main oven fan in
Remove the cover at the rear of the oven compartment, then holding the fan blade with one hand, undo the nut holding the fan on, it is a left hand thread, so turn the nut clockwise as though you were tightening it.
To remove the motor itself you will have to undo 3 screws securing the fan motor from inside the oven compartment, then remove the outer rear cover of oven to remove the motor.
Posted on May 10, 2011
Testimonial: "Thanks for the straight forward instructions!"
Tip
How to fix a Hotpoint fan oven that trips the circuit breaker or has no heat
In this video I dismantle, diagnose and fix a Hotpoint fan oven that was tripping out the earth leakage circuit breaker. It was the heater element which is easy and cheap to replace.
on Dec 02, 2015 | Hotpoint Ovens
Hotpoint oven does not work , but grill works fine. switched off and reset manually but still not warm enough.....
If the oven fan is working o/k, then you need to replace the oven elent located at the rear of the oven compartment behind a removeable cover.
Feb 01, 2011 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint oven is not heating up
If it is a fan assisted oven and the fan is working o/k, then you need to replace the oven element.
This is located behind a removeable cover at the rear of the oven compartment.
Oct 15, 2010 | Hotpoint Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint BD35 oven fan not working
The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
Hope this helps.
Jan 15, 2010 | Ovens
My hotpoint bs32 oven went bang when I turned it on aftewr a while. I replaced the fuse and the grill and all the functions light up and work except the oven. The fan is working but the oven is not warming...
The fan oven element has failed, you need to replace it with a new element.
You need to remove the inner rear cover of the oven.
There you will see the element..
Unscrew and disconnect the leads and refit new element, be care ful not to lose the wires behind the element aperature.
Thanks.
Jan 05, 2009 | Ovens
Nut is not tightening on the fan hotpoint oven
It is a left hand thread, so you fasten it as though you were normally unscrewing it.
If it still does not tighten then you have a stripped thread on the nut or the fan spindle.
Plz leave feedback.
Ta.
Dec 09, 2008 | Ovens
Ovens Logo
29 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
