Question about Refrigerators
I have a large collecting of coke memorabilia two personal small fridges less than a year old do not work anymore please tell me how I can talk to someone that can help me to get them fix
    Top Expert:
  • Refrigerators Master
  • 51,518 Answers
Contact any local repair service .
Posted on Aug 09, 2017
HVACRH20
  • 237 Answers
SOURCE: Fridge/Frezer stop working
Can you tell if the compressor (black soccer ball looking thing in the rear of the unit) is running? Is it really hot? Is the little fan running near it? If the compressor isn't running it won't cool. Also check that the coil in the freezer section isn't frozen solid blocking all air flow inside the unit. The other thing is that the defrost cycle may be "stuck" so it thinks it should be defrosting (therefore not running the compressor, etc.) Lots of things to check but that info will help decide which way to go so post what you find please.
Posted on Dec 31, 2006
  • 8 Answers
SOURCE: hotpoint fridgefreezer FFS70
if you have no cooling at all it means that a no gas charge b locked  in defrost c thermostat d compressor not working
Posted on Oct 31, 2007
docjohn174
  • 943 Answers
SOURCE: Amana bottom drawer fridge/freezer combo
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: when someone calls I can't hear the person unless I use my hands free device
That person can use the headset or loud speaker
Posted on Oct 24, 2008
SOURCE: samsung cash register needs price change, need someone to hire
what model samsung do you have?
maybe I have the manual
pepogabo@hotmail.com
Posted on Nov 28, 2008
How do I resolve this? My refrigerator is 17 years old should I just replace the refrigerator?
There are a lot changes in the market with new units. You can also get energy credit.
Dec 22, 2017 | Refrigerators
I need to know who to contact about getting my personal small coke fridges fix. They were a gift. Last christmas
https://www.cokesolutions.com/equipment Coca Cola Refrigerator Repair https://www.fun-tronicsllc.com/
This is not an easy question. More detail about your unit would help.
Possibly American Retro would have e some 3rd party repair person you could contact, but maybe not. Meanwhile, here are some machines sold via Walmart.
Coca Cola 10 Can Retro Vending Fridge Walmart com
Aug 09, 2017 | Personal Computers & Internet
My fridge freezer is less than 2 years old and the freezer is not working could it still be under warrenty?
If your fridge is self defrosting then you probably have a stuck defrost timer motor/switch. I can usually be found on the bottom of the front ourside of the fridge. You can try to advance it with a screw driver until you hear a click and once you do hear that click the fan and the compressor should turn on. Ifthey do then you will need to have the defrost timer replaced. After two years I doubt it is in warrenty. The only things that should be in warrenty is the compressor and all of the related tubing in the hermedically sealed unit..
I have had this problem many times and since I am a retierd HVAC engineer I was able to fix these defrost timers, mainly the actual motors that had dried bushings. You would first have to take the timer apart and get into those bushings and use a small amount of a good light oil like 3 in 1 oli. That usually does the trick.
Hope this helped you. If it did then would you please let me know, I would be courious to know.
Good luck,
Marty
Jun 26, 2014 | Beko Fridge/freezer Thermostat Genuine...
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water collection in fridge
.you need to check the drain to make sure it is not clogged or blocked that would stop the water defrosted from you evaporator coil from draining into the drain pan.rare occasions the unit will stay in a defrost mode while trying to cool causing alot more water to be draining.good luck with your fridge.let me know how things go for you.
Jan 22, 2010 | Refrigerators
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
Water collecting on bottom of 13 year old fridge
All refrigerators create water when their cooling coils shed frost build-up - that water typically collects in a tray under the fridge body through a drainage tube that exits from a collection trough inside the fridge under the coil through the back of the fridge housing.
First check the tray to be sure it is not accumulating food particles which ultimately can produce molds. Clean any water from that tray first, then look for the tube exiting on the back of the fridge see whether there is any moisture at the end of the tube under the fridge and notice whether the tray has had any recent moisture. Chances are the tube is either plugged or similarly any connector through the fridge wall.
Now, be CAREFUL not to puncture the hose or the connector with a sharp instrument however the drain path must be cleared. Try blowing through the drain inside the fridge with a straw, then add a small amount of baking soda into the collection trough, adding a small amount of water to dissolve and allow this to gradually drain out normally. Only detach the outside tube if the problem has not been resolved in this manner. The tube can be replaced easy enough, the connector through the back is another question - see you parts dealer if it has been compromised.
Jul 05, 2009 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
Ariston fridge freezer
hi smyvilla
on some fridge freezers there is a channel which is designed to take condensation from the fridge out through a small hole at the bottom of the back wall of the fridge check this hasnt got blocked or iced over, if the unit is a few years old it is possible that there has been some evaporation or leakage of the coolant mixture, that may be whats on your floor, the pump can therefore no longer pressurise the mixture sufficiently to cause it to remain cold,
Oct 25, 2008 | Refrigerators
New Fridge Water Dispenser (Inside Fridge) Stopped Working
talk to the person you bought it from and ask them what warrenty is, there is no quick fix or i would give you one
chrs
Mar 31, 2008 | Refrigerators
Looking for a fridge with narrow depth and finding it hard.
i need an american fridge freezer depth less than mm and wudth less than 90mm
Apr 09, 2007 | Hotpoint RLA80 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
