Question about Vax Vacuums
I need user manual for a Vax Appliance INC. model 221. Is this a wet/dry vacuum.
blueextc3221
  • 15935 Answers
SOURCE: I do not have my
no - simply remove the filter. That is the only step necessary!!
Hope your cleanup goes well!!
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Jan 31, 2009
  • 18 Answers
SOURCE: manual for Bissell 1672 BIGgreen Wet/Dry Vacuum
Here is the user guide for model 1672 in either English or Spanish: http://www.bissell.com/searchresults.aspx?searchtext=1672&mode=userguides
Posted on May 25, 2010
gsegan
  • 4 Answers
Vacuuming Liquids
1. When picking up small amounts of liquid
the filter may be left in place.
2. When picking up large amounts of liquid
we recommend that the filter be
removed. If the filter is not removed, it
will become saturated and misting
may appear in the exhaust.
3. After using the vac to pick up liquids,
the filter must be dried to reduce the
risk of possible mildew and damage to
the filter.
4. When the liquid in the drum reaches a
predetermined level, the float mechanism
will rise automatically to cut off
airflow. When this happens, turn off
the vac, unplug the power cord, and
empty the drum. You will know that the
float has risen because vac airflow
ceases and the motor noise will
become higher in pitch, due to
increased motor speed.
IMPORTANT: To reduce the risk of damage
to the vac do not run motor with float
in raised position
Posted on Jun 15, 2010
SOURCE: i have a vax wet/dry
If you still need a manual, I have one I can scan and email?
Posted on Mar 24, 2011
javeedcare
  • 316 Answers
SOURCE: I have an old shop
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Posted on Jul 04, 2011
How can I download user manual for Vax 2000 wet and dry carpet cleaner ?
Try Googling (vax)(2000)(manual) without parens.
Jun 17, 2017 | Vax Vacuums
Vax action 602 manual
There are several models of the Action 602 by VAX. The manuals are available on the company's support site: http://support.vax.co.uk/ . Use the search feature to find your particular model. The direct link to the manual for the Vax Action 602-AN-Be is http://library.vax.co.uk/resource/1086/u86-an-range/user-guide.pdf .
I hope this helps.
I hope this helps.
Aug 12, 2016 | Vax Vacuums
Manual for vax 121 wet & dry hoover
I need a VAX wet/dry vacuum model 221-07 manual.
Apr 28, 2011 | VAX Appliances V037 Stick Wet/Dry Vacuum
Water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
VAX Petvax Operating Manual
Check Vax.co.uk they have an online user manual section.
Specificially:
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Dont forget to rate appropriately, thanks.
Mar 27, 2009 | VAX Appliances Vax X5 Bagless Upright...
Rechargeable battery
Hi, try looking on ebay, user name; itl-e. His shop name is; Component-shop. A wide range of batteries supplied including a 6V 5AH which sells for about £8 including p&p. Your Panasonic battery is rated at 6V 4.2AH, so the replacement will last slightly longer between charges. If you want an exact (Panasonic) replacement, try putting "Panasonic LC-R064R2CH into google.
Hpoe this helps! Bob.
Oct 05, 2008 | VAX Appliances V037 Stick Wet/Dry Vacuum
Manual for Bissell 1672 BIGgreen Wet/Dry Vacuum
You can download the Manual at http://www.bissell.com/images/UserGuides/1672.pdf, I hope this helps.
Aug 06, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Vacuums Logo
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
