Question about Vacuums
Vacuum stopped running won't start up
While vacuuming the vacuum shut off. it will not come back on
LizDahl
  • 75 Answers
SOURCE: aerus lux 5500
There is a red button on the head of your power nozzle. It is the reset button. Try hitting it and see if that helps.
Posted on Jan 14, 2008
  • 184 Answers
SOURCE: Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Posted on Feb 07, 2008
  • 460 Answers
SOURCE: my vacuum has stopped working and shut off in the
no power, plugged/jammed impeller. some newer ones have a sensor that turns it off when it is full of dirt...
Posted on Nov 09, 2009
  • 70 Answers
SOURCE: My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Posted on Nov 16, 2009
SOURCE: U5180-910 vacuum shuts off on own
WARNING, DO NOT BUY THE HOOVER PLATINUM SERIES:
Piece of junk, out of the box it shuts down after 20 seconds of operation. Also when you raise or lower it it will shut down,
What happened to Hoover???
My moms is Hoover 35 years old and still working even though I tell her to buy a new one year after year.
Maybe shes right.
Mike in WI
Posted on Nov 26, 2009
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
Vacuum runs for awhile and then shuts off
This sounds like an overheat issue. I suspect that something has restricted the air flow. Air flow is required for function and to cool the motor. if the air flow is restricted a thermal limiter opens the circuit, rather than have a fire.
Mar 04, 2013 | Proteam ProForce® 1500XP Bagged Vacuum
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
DC07 Shuts Off, won't restart
If it was running for a while... It may be overheating. It has a reset: http://www.ehow.com/how_5943288_reset-dyson-vacuum.html
But maybe just let it cool for an hour or two and try it again?
Oct 07, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson cylinder i was sucking a vacuum space saver bag and my vacuum just stopped
Hi Philip,
Your DC11 is equipped with a safety device which shuts the cleaner down if it starts to overheat. It's likely that this is what occurred, as there may not have been enough airflow through the cleaner to keep the motor cool. If you unplug the cleaner and leave it to cool down for at least an hour, you should find it will work again.
If the cleaner still won't run after this time, get in touch with us directly so we can provide further assistance - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 31, 2011 | Dyson DC11 All Floors Bagless Canister...
The vacuum stopped running while vacuuming, won't turn back on. Have only had 2 months.
Take it to the local vacuum repair shop. The work cheaply most of the time and know exactly what is wrong. May do it while you wait. Most towns have at least one or two good shops. something like that is just too difficult to diagnose on fixya.
Aug 12, 2011 | Vacuums
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
