Question about Panasonic Audio Players & Recorders
Panasonic se-3080 has no sound or lights on tuner and no movement from tape drive r lights.
Turntable gets sound, but tuner lights out and no sound. No sound or movement in 8 track. Problem started with 8 track popping noices and thenlost lights in it and tuner. Popping when selectiving radio/turntable/8 track.
vitg55
  • 78 Answers
SOURCE: turntable makes a popping noise
The problem with turntable motor or coupler which sits on turntable motor shaft.
Posted on Dec 01, 2008
  • 24 Answers
SOURCE: Getting occasional popping sound through
Describe your system in greater detail. Does the preamp have a mechanical selector for the tuner/phono/CD or does it have a digital selector that you can operate with a remote? The problem might just be a dirty selector switch that need to be sprayed with Deoxit contact cleaner. It could also be bad cables so try swapping cables with the tuner.
Posted on Dec 28, 2008
SOURCE: mid 70's sears turntable. plate will not spin.
take a soldiering iron and touch it to the metal in the center of the platter for a few seconds. this will heat up the grease on the inside and allow the platter to budge. should work fine afterwards. what happens is over time the grease hardens and locks everything up. applying some heat will loosen things up and get it running again
Posted on Sep 15, 2009
  • 88 Answers
SOURCE: Microwave turntable guide
it could cause the magtron to arc...becaus the exsposed metal...you can purchase the paint for the inside color of microwave...sand around area..wipe out,,,unplug microwave first....leave door open ,spray it ,let stand couple of hours or 1 day...hope this helps...michael doctorr airr appl.repair 843-384-8474..call if need assistance..good luck
Posted on Mar 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
Posted on May 17, 2010
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
Why can't I get my turntable to sound right on my
Turn table? You mean like records? lol
The output of record players is different voltage than like cd players, etc...
Does your stereo have input for turntable or are you hooking it up to an extra rca input? I had mine hooked up wrong before and it did same thing.
Dec 11, 2011 | Denon Audio Players & Recorders
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Vestax PDX 2000 motor going crazy problem
hey, it will work with the tape solution but you gotta pay attention to the light metallic circle which is used by the light sensor (the small black one with cables on it) to estimate motor movement - first time i opened it and did the tape thing to the black rubber circle i eventually touched the light metallic circle and i think that caused it not working for me too
the light metallic circle must be totally clean and plain, do your best, but be sensible
Jul 09, 2010 | Vestax Pdx2000 Direct Drive Turntable...
I can't get much sound from my tuner/receiver. I have tried all possible connections.
"Much" sound? What's that mean? Very low, almost silent, tinny?
"There is a switch on the bottom panel, next to the RCA cables, that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable (PHONO) input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input."
Apr 03, 2010 | ION Audio TTUSB10 Turntable
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
I cant find the operators manual for Panasonic audio rack system
 http://service.us.panasonic.com/operman/findmanual.aspx?cat=AUD
This link is for multiple Panasonic sound devices.  I am not sure whether your models are on here, but have a look.
Apr 06, 2009 | Panasonic Audio Players & Recorders
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
27 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
