You can not fix a leak in a coil. I fixed one coil in 10 years and it's because it was brand new and I put a screw in it. I am a seasoned brazer with years of experience, your coil can not be repaired, it needs replaced. Hopefully it's under warranty, that's $500-700 vs $1500-1700 approximately.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: 97 jeep brand cherokee limited
located on passenger side below heater box toward the bottom of the firewall. going to be about a 1/2 tube sticking out about 1 to 2 inches.
SOURCE: condensate leaking on passenger side from ac
The drain tube from the evaporator housing is most likely plugged up. With the vehicle in the air locate the drain tube on the passenger side of the firewall and using coat hanging or something similar carefully snake it through it Be careful as a lot of water may pour out and don't go crazy poking with the coat hanging as the evaporator core is at the other end of the tube.
SOURCE: location of ac condensate drain , it's plugged and
The weep drain is located on the left and right sides of the firewall and you may see a rubber tube sometimes, and hear a sloshing of water building up, unless, it's all leaking onto your floor.
