Question about GE Refrigerators
GE smart twist double water filter undersink has no water flow, I changed the filter not got low water. What needs to be done here?
  • 35 Answers
SOURCE: icemaker and water dispenser not
generic troubleshooting video:
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Posted on Apr 03, 2008
SOURCE: Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Posted on Apr 29, 2008
  • 1543 Answers
SOURCE: Water won't flow from GE Smart Water under-sink RO water filter
Disconnect the water pressure tank making sure the end the line hooks up to is open. The tank should be relatively light, and if you shake it you should not hear any water. If you hear water in it, or it feels heavy, that means the bladder inside the tank has failed. Replace the tank with a new one, and set the pressure on the bicycle type valve at 8 PSI before you connect the tank up to the water line.
Posted on Dec 09, 2008
SOURCE: Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Posted on Mar 22, 2009
SOURCE: Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
Posted on Jul 22, 2009
How to restore lost water pressure after replacing undersink filter?
make sure the filter is going the right way.They have one direction.
Jun 20, 2015 | GE GXRLQR GE SmartWater Inline Filter...
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
No flow from EcoWater undersink filtration unit. Flow stopped so we changed two carbon filters and one sediment filter. Still almost no flow.
The water storage has probably lost its charge. A 3 gallon tank should have 7 psi pre-charge pressure. Tank has to be totally empty to set pre-charge. Turn water off to RO, pump air into tank to force all the water out at faucet, turn tank valve off and relieve pressure until 7psi charge.
Nov 28, 2009 | Culligan Under Sink Water Filter
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE smartwater under sink filter shuts down after changing filter
run water through the unit with no cartridge in place. Then check the filter to be sure it does not have an obstruction in it. Finally, replace the filter and your pressure should be fine. Good luck.
Jan 19, 2009 | Home
Water Dispenser
water fill valve or if equipted need to cnage water filter
May 06, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
