Question about Electrolux Kitchen Ranges
Trying to use the self clean on my Electrolux range. It keeps saying that I must remove the racks in the oven, but they are removed.. Any suggestions?
    Top Expert:
  • Electrolux Master
  • 51,186 Answers
Pull them out till they stop then lift front edge and pull rest of the way out.
Posted on Aug 09, 2017
4 Suggested Answers
SOURCE: I cannot get my Electrolux
I finally figured it out! The rack supports actually come out also. Not just the sliding supports, but the whole metal part with all the supports on it. At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in....
Posted on Feb 21, 2009
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
  • 523 Answers
SOURCE: Removed racks and rack support from my Electrolux
turn off power the back on
Posted on May 27, 2010
I can't self clean the oven because it says remove racks. They are all out, including side racks. Switch isn't jammed on the left side.
Hello Laurie, thank you for your post!
Based off what you have described your Electrolux wall oven will not start self-clean due to the oven stating the racks need to be removed. You may need to perform a reset on the oven to clear out the code. A reset can be done by disconnecting power from the oven for at least ten minutes this can usually be done by flipping the household circuit breaker off. If that does not help to correct the issue you may need to have a professional out to your home for a proper diagnosis and repair. -Matt
Apr 10, 2016 | Electrolux EW30EW65GS 30-in Electric...
Message to remove racks when trying to self clean,yet all racks have already been removed.
This message is a reminder to make sure the rack are removed only. If they are removed then continue with the self clean cycle. Good Luck
Mar 22, 2016 | Electrolux 30" Built-In Single Electric...
We have an Electrolux Wave Touch a Dual Fuel Range and cannot use self clean upper often feature due to flashing "remove racks" message . Have removed all racks, and ensured rear vertical metal bar is
Hello friend, thank you for your post!
I would perform a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. Upon restart I would operate self-clean to see if it will allow you to do so. If your appliance will not start self-clean you could be seeing a problem with the UIB (user interface board) or EOC (electronic oven control) and I would suggest having a professional come out to properly diagnose your appliance. Hopefully this is helpful. -Matt
Sep 04, 2014 | Electrolux Kitchen Ranges
Electrolux dual fuel range 316471210 self clean remove racks message displayed and cannot proceed
Hi friend, thank you for your inquiry!
I understand that you are receiving a "remove racks" message on your Electrolux range. The oven racks and supports must be removed before the self-clean will initiate or the control will not allow the self-clean to turn on. I hope this is helpful. -Matt
Electrolux Icon range won't self clean - "Remove Racks" displayed
Good Morning Friend,
I understand you are unable to self-clean your Electrolux Icon range, model# E30SO75ESS, due to it stating "Remove Racks", when you already have. Please follow these instructions for cleaning your oven:
1. Remove the turntable from the oven before the Refresh Cycle. No food should be in the oven.
2. The Refresh Cycle is 30 minutes.
3. During the Refresh Cycle some smoke and odor may occur. Open a window or use the ventilation fan in the room.
If this does not help, I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try the "Refresh cycle". I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
Trying to set it to clean, but it keeps saying remove racks even though the racks are out.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 11, 2010 | Electrolux 30" Self-Cleaning Slide-In...
When I try to use the self-clean program, I remove the racks but then the cleaning cycle won't start and the "remove racks" indicator is flashing. There is a vertical metal piece in the back of...
I just did the self clean function today. They need you to remove the rack supports from each side of the oven cavity. Simply pull up on them to remove. When I did this the message was not displayed and the slef clean function started. Hope that helps.
Darren
Nov 15, 2010 | Electrolux 30" Self-Cleaning Freestanding...
How to remove oven racks for cleaning my electrolux oven
Push the racks all the way to the rear of the oven. Lift the rear of the rack to dislodge it from the side rail and pull it out.
Nov 19, 2009 | Electrolux 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
106 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
