Question about Lands Phones
How to enter programming mode chsu40a - Lands Phones
When in night mode, how do I make the samsung idcs 18d ring on every extension
if you know your password for your phone system do this. enter programming mode by pressing transfer key, type 800 enter your password then volume up key then speaker key. go to program 601 station groups find unused station group ie 510. make this group unconditional and under members add all thr extensions you want to ring then press speaker key. then go to program 406. enter line number of line and under night mode tell it the station group number you programmed above
May 07, 2014 | Samsung Falcon iDCS 18D Display Phone with...
2001 mustang keyless entry not working properly what do I do
You did it like this ?
Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
  1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
  1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
  1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Jan 15, 2018 | 2001 Ford Mustang
How do I program the scanner. It keeps telling me there is an error when I enter anything. Any help would be greatly appreciated.
I have one of these scanners they are kinda hard to program uniden could of made it simple.....Ok you have to hit your function button first...Then hit your e button enter button the enter button and it will go to program...The enter button and the program button is the same just go to your enter button. e button this will put your scanner into program mode...then you can start entering your frequencies...if you don't have it in program mode it will show error...If you have any more problems you can e mail me randymarr570@msn.com
Jul 16, 2011 | Uniden BC72XLT Handheld Scanner
CANT TUNE IN MY SCANNER
put your bc72 in program mode.. hit you e button your enter button..but first put your scanner in function mode... then hit your enter button this will put your scanner in program mode and you can start entering your frequencies into it....if you have any problems biddy mac you can email me at randymarr570@msn.com................
Jul 02, 2011 | Uniden BC92XLT Handheld Scanner
How to take my viper remoter off vabration. a where can i find the manual for the viper remoter
To enter programming mode Press the Program button on the back of the remote or hold the four remote control buttons on the front of the remote simultaneously until one long beep is heard. Programming Mode has now been entered.
Beep/Vibrate Mode Within five seconds of entering Programming Mode, press Lock. The remote control will beep once for on, twice for off. The vibrate icon (13) will also turn on/off with each press.
Here's the owners manual for that system: http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
remote programming starts on page 15.
Mar 25, 2011 | 7701V Responder SST Remote
I need NOMA N1508 manual.
answer 1 Function and operation
1 - This timer has 3 working modes
a - Auto Mode(AU)
b - Auto and Temperature Control Mode (AC)
c - Manual Mode (LL)
Press "MODE" button and the LED display will cycle through these three modes.
2 - There is an output indicator light which turns Green (On all modes) and red (Off - manual mode)
3 - There is a bettery backup that can retain programs for about 1 week after power outage.
Operation
1 - On first use . Connect the unit to 125V AC power source. The LED display blinks 'C'. The unit at this moment is in initial state, where time and program need to be set.
2 - Press the "TIME" button, the LED display will now show "12.00", now the unit is entering time setting mode
a - The time interval for this product is 15 minutes
b - Press "TIME" button again. LED dislays 12:15 with each press of the time button the time increases by 15 minutes. If you press and hold the time button for 2 seconds the LED will increase rapidly.
c - After setting the time, press the enter button and the LED will display current time setting.
d - To change the clock press the "Enter" and the "TIME" buttons simultanously to enter the editing mode. Press the "TIME" button to adjust the time. Press the enter button to confirm
3 - To program press "mode" button once and the LED will display "AU" which stands for Auto Mode, press the "MODE" button once again and the LED will display "AC" which is the Auto and Temperature Control Mode. Press the "MODE" button once more and the LED will display "LL" which is Manual Mode. Press enter to confirm the selected mode. Press "MODE" button to role over these three options.
a - Auto Mode
Press "MODE" button and the unit will enter Auto Mode, LED displays "AU"
- Press "ENTER" button to confirm. LED displays "P". Press "TIME" button to set program ON time.
- After the program ON time is set press "ENTER" button to enter program ending time. LED will display "E". Press the "TIME" button to set the ending time.
- Press "ENTER" button to return to normal time display mode.
- The program indicator will be turned on after the ON time and ending time have been programmed
- Press the "TIME" button to review the program ON time setting and program ending time setting. The LED displays "P" and "E" respectively. After that the LED displays the current time.
- In case you want to modify the setting repeat step "a".
*** Note: When entering your program if no action takes place within 15 seconds it will go back to the time screen.
Press the "MODE" button and the LED will display "AU". Press the "MODE" button again and the LED will display "AC". press the "ENTER" button to confirm.
- The timer activates the load only when the folloewing two conditions are met:
1 The temperature is below -10
2 The program on time p is reached
For instructionsn on how to set the program ON time and the program ending time please refer to the Auto Mode fucntion
- The program indicator will be turned on after the ON time and the ending time have been programmed.
- When the program ending time is not yet reached, the load will be deactivated if the temperature rises above -7 and will be activated again if the temperature drops below -10. Once the prgram ending time is reached the load will be deactivated regardless of the temperature.
C - Manual Mode
Press the "MODE" button to select Manual Mode. When the LED displays "LL" press the "ENTER" to confim. The LED returns to show the current time. Press the "TIME" button to activate the timer the LEd will display ON. Press the "TIME" button again the LED will display off.
- In Manual Mode the output indicator will display red when the load is deactivated and green when activated.
- To exit manual mode press "TIME" and "MODE" buttons simultanously and the unit will return to Auto mode. The loading will be activated and deavtivated according to the previous setting.
4 Output indicator
1 - In Auto Mode ort Auto Temperature Control Mode when the loadind is deactivated the output indicator tunrs off.
2 - In Manual mode the outpur indicator turns red when loading is deactivated.
3 - In Manual Mode, Auto Mode and Auto Temperature Control Mode the output indicator turns green when the output is activated.
To reset all of your settigns including current time and programs, press and hold the "ENTER" button for 5 seconds from the "TIME" mode. answered 3 weeks, 2 days ago by Anonymous
Jan 11, 2011 | Sport & Outdoor - Others
I want the security feature to the remote disabled how do I do this?
To de-program the RKE fob from the 1st truck ( the 1998 one ? ), enter programming mode. I had to try 3 times on my 2001 to enter programming mode, and thought I did it the same each time, obviously I did not, so do not give up if you do not enter programming mode the 1st time.
Once you enter programming mode ( locks cycle ) wait 30 seconds, and programming mode should exit. Entering programming mode for the RKE fobs erases all previous RKE fobs.
This should cure the problem with the RKE fobs being programmed to 2 different trucks.
The RKE ( Remote Keyfob Entry ) is not a security feature, just a convenience item, so you are not disabling any actual security item.
Oct 06, 2009 | 1998 Ford F150 Regular Cab
Toshiba Strada, Model CHSU40A- Need to re-set voice mail passwords and message
I am guess that you have a Stratagy voicemail. If you do call the voice mail extension and press * and log into mail box 999, the security code is usually 999997 or just 997. press 8 for admin features, more on this and guides too visit here
http://guides.idacomusa.com/
Jul 28, 2009 | Toshiba DKT2010SD Phone
Entering y1 in program mode
First, you cant put Y in Y(X)
Hit [2nd] [ALPHA] [0] [1]
Jun 25, 2008 | Texas Instruments TI-85 Calculator
How do I change the time?
The Macrotel Excel, Macrotel MT-16 and the Prostar 816 are all very similar in programming. The following information should work on all 3 KSU's of any revision or software level.
To Enter programming: Must be done before any programming
Depress # (Programming)
Dial 20 (MMC Disabled)
Enter Password [Default is 1234] {or it may be 4321}
Dial 1 to enter programming mode. Programming mode will turn off automatically after a few minutes of non-use.
Dial # again
Then
To change Time and Date:
Depress
# (Programming)
Dial 55 (YY MM DD W HH MM)
Input new data:
YY= year
MM= month
DD= day
W= weekday [0=Sun 1=Mon 2=Tue 3=Wed 4=Thu 5=Fri 6=Sat]
HH= hour (24 hour mode)
MM= minute
All data must be entered each time or changes will not be saved.
Dec 04, 2007 | Samsung Prostar 824 Keyset Telephone
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
