Question about ASUS Motherboard, nForce 570 SLI, Core 2, 1066Mz, ATX, Max 16GB DDR2, 2PCIEX16, 3PCIEX, 2PCI,GBE,Aud,SATA (ASU-P5NSLI GREEN)
P5NSLI USB will not work. BIOS seting is ok. - ASUS Motherboard, nForce 570 SLI, Core 2, 1066Mz, ATX, Max 16GB DDR2, 2PCIEX16, 3PCIEX, 2PCI,GBE,Aud,SATA (ASU-P5NSLI GREEN)
  • 53 Answers
Hi good day, about your problem, I think you must first check in your system properties if all the drivers are installed, windows XP pro operating system usually supports all drivers for usb. Also download the driver for your motherboard at the manufacturer site and be sure to download the latest updates. Good luck
Posted on Jul 28, 2009
Need hdd password for dell inspiron n7010 laptop
eracing the hard drive wont work its a seting in the bios most times its admin or password if not then go into bios to remove it
Jan 14, 2014 | Dell Inspiron N7010 Laptop Core I3 2.4ghz,...
I have an asus pn5sli mobo with 8 gig ram, nvidia 9800gt gpu,running windows 7 and am having crash issues.can you update bios using a usb as I have no 1.44 floppy installed and can you increase ram voltage...
Hello download your files here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5NSLI/#download
Download asus update in the utility for 64 bit system
Next download the latest bios
Please unzip the files before you install.
Install asus update and select update bios from file.
This can be done while the system is running.
Select the bios file you have downloaded
and the program does the rest.
Remember to download the right bios.Flashing the bios with a wrong file will damage the mainboard !!!!!!!!!!!!
And you need to set up bios when the job is done (the boot sequence)
Good luck
Dec 17, 2010 | ASUS P5NSLI (0610839134670) Motherboard
Usb driver 2.0 dont work
There are USB 2.0 drivers for different manufacturer's, are you certain you ave the right one?
Maybe use a driver finder program to find the exact driver required.
May 14, 2010 | ASUS P5NSLI (0610839134670) Motherboard
How do i clear the cmos on my asus p5nsli
support.asus
just to clarify, to clear your BIOS, there should be a 3 pin set on your board usually located some where just below your RAM. On the board will be printed something like "CLR" or "CLEAR" move the pin connector, with the power off, from its current position to the middle pin and the open pin. Wait about 15 to 20 seconds and move the connector back to the original position. You have just reset your bios to factory defaults.
Oct 18, 2009 | ASUS P5NSLI (0610839134670) Motherboard
How fix p5nsli no vga for monitor and no video with videocard?
this motherboard does not have ANY onboard video. if your video card/cards only have DVI i suggest you buy an adapter for vga or a new moniter. If you dont have a video card installed then you obviously need one. i suggest 2 decent ones since the board is sli/crossfireX certified.
Aug 21, 2009 | ASUS P5NSLI (0610839134670) Motherboard
None of the USB hubs work (MB: P5NSLI)
The reboot did not locate new hardware?
Do they still make a usb card that will plug intio the PCI slot? If so way to go is just put one in. or new MoBo
Jul 27, 2009 | ASUS Motherboard, nForce 570 SLI, Core 2,...
Fan overspeeding / usb ports not working
I'm glad that fixed it!
(Posted as a solution so that you can rate the response.)
AMDFan, update to the most recent BIOS and that should fix the problem. It fixed death88scyth's issue, I see no reason as to why it won't fix it for you.
Mar 25, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
My Motherboard running but no beep no display of bios how can I solve the problem
refix your ram after clean it.also reset your bios setings .put your cmos cell for 15 minutes away from other bord.
also u can reset your bios setings with jumper setings.it is nearly cmos cell or corner of the motherbord put in 1-2 position then power up the cpu then refix again to its original position.
Dec 29, 2008 | Intel D946GZIS Motherboard
hi mickeymaas,
please have it check in your bios if its enable or not, if its not then have it enable and restart your computer, this usually happens when we did not properly remove usb devices . If you dont know how to go to bios, just remove the other devices and restart your pc
then put all those devices back., except for the mouse and the keyboard.
:) Allen
Jun 12, 2008 | ASUS Motherboard, nForce 570 SLI, Core 2,...
ASUS Motherboard, nForce 570 SLI, Core 2, 1066Mz, ATX, Max 16GB DDR2, 2PCIEX16, 3PCIEX, 2PCI,GBE,Aud,SATA (ASU-P5NSLI GREEN) Logo
443 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
