Question about Freezers
The power in my freezer is not kicking - Freezers
When the compressor kicks in it causes a power surge that shuts off my TV. Solution?
Plug the unit into a different circuit. You are pulling to many amps on that circuit to run both
Jan 19, 2015 | Danby Deluxe Mini Fridge with Freezer...
Why does my upright freezer runs then kicks off, runs then kicks off?
Good Afternoon Friend,
I understand your Frigidaire freezer runs for a short time and then kicks off. Then it turns on with a click and repeats its cycle. This is how your freezer functions. When it needs to cool, the compressor will kick on and cool until the temperature is reached. Then it will kick off until it needs to cool again. It's possibly due to the hot and humid summer that it is cycling on and of more. I hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
How to fix freezer power kick off
Are you referring to the defrost timer or a circuit breaker ??
Jun 01, 2014 | Freezers
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Power outage and freezer is now flashing "e" on display
look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
Jul 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Freezer 20.3 cu.ft. won't kick on
Poor mom..:) You need a technician for that problem. But much better if you buy new one because your unit is already 14 yrs old the labor and parts are expensive. For this problem I think the compressor is already burned or stuck up.
Jan 04, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
63 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
