Question about Pool & Spa
Set up filter vaccuum pump manual - Pool & Spa
My GE front load washer WBVH5200J1WW washer pauses at the 13 minute point in a 59 minute cycle, It shows no error codes
I would inspect the pump. It could be draining to slow. There should be a small door at the bottom of the machine. Pop the door and you'll have access to the pump filter. The filter unscrews from the pump housing counterclockwise. There will be some water that will come out. Using a wet vac, slowly unscrew the filter until there is a small amount of water coming out. Have the vaccuum on and ready. Vaccuum till there is no more water. If you don't have a wet vac, then a couple towels will do the trick. Completely unscrew the filter and pull it out. Hopefully you will find, a nest of change/hair/bra wire/bobby pin ect. I've seen it all :-) Once you have cleaned the filter or failed to find anything, reach with your finger into the right side of the housing, there will be a hole. Reach until you feel the impeller. It should have 4 fins and shouldnt have a lot of play. The pump will need to be replaced if this is the case. If this doesn't help, then you should have a tech come out. Find a small time repair place with little overhead. This is where you will usually find the best prices AND service.
Apr 05, 2013 | Washing Machines
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Since you have access to the internet there are great amounts of manuals online now. Just be very careful about making sure that you DO have it unplugged when you start!!!
May 22, 2012 | Pool & Spa
When i turn y pup on, the filter almost seems to
you have a problem with top valve on filter check to see if sprocket is not seated right you have to remove handle assembly to see sprocket
Jul 06, 2009 | Hayward SAND FILTER, PRO SERIES
Sta-Rite S7M120
The brown-green gunk sounds like algae. You stated that you have cleaned the filter. Have you taken the cartridge completely out? If not, I would suggest that you do so. Scrub the inside of the filter tank with a 4:1 bleach water mixture, only 1 part bleach. Then soak the cartridge in an acid bath, like Muriatic Acid. This will kill any algae that is in the filter itself.
You may need to vaccuum your pool to waste, get rid of some of the water and refill it. This may help get the chemicals in order.
Another idea would be to run the system continuously for a couple of days. Vaccuum to waste, not to return lines, and clean the filter when it reaches 8 to 10 PSI above start-up. You may not be running the pump long enough to properly filter water. Keep trying to get chemicals in order.
Jul 05, 2009 | Sta Rite Sta-Rite Hydro 120 ft. Filter...
Vaccuum under the air filter box runs even when the key isnt in
It sounds like your air pump is malfunctioning. It is used to pump emissions out the back of the car. it is controlled by a vacuum. These will drain your battery if the vacuum does not send a signal to shut it off.
Dec 24, 2008 | 1999 Volkswagen Passat
Honeywell HFD-135 -- lost instructions -- how do i clean removable filter?
Manual can be found here:
Sep 10, 2008 | Kaz Honeywell QuietClean HFD-135 Air...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
