Question about Sirius Car Audio & Video
I have a 2009 Kia Rondo EX with a sirius Radio with the touch screen display with navi, but i ran into a problem. One road trip, the radio display went weird and now it is always stuck at the loading "Kia Motors" screen. i can't access setup, navi, cd drive, but i can still listen to my radio and my aux. I wish to fix this either myself or send it in to a shop and have them do this and not everything else.
SOURCE: Radio Antenna Adapter for Sirius radio add-on
Brought problem to my trusted auto mechanic and he found a simple disconnect/connect where to antenna cable comes into car under front right side under the glove box. It took literally 30 seconds to do.
Posted on Jun 19, 2008
doin12volt
  • 233 Answers
SOURCE: missing AUX 2 after changing car batterie
hold the SRC button until the stereo turns off. Hold in on the function button (or volume knob) until the setup menu turns on... once it comes up, you can scroll thru selections with the volume knob and turn them on and off by clicking in on the knob. AUX2 will be one of those settings.
Posted on Jan 19, 2009
SOURCE: Sirius Problem
The sirius unit does not have any channels in the unit.
You need to refresh the radio (XM allows you to do it online, I dont know about sirius) and leave it powered on for about an hour for it to update the channel list.
Posted on Mar 13, 2009
  • 28 Answers
SOURCE: 2004 Accord EX CD changer ERR and display blank
This is the Radio Anti Theft feature which is activated whenever there is a complete power loss to the radio (as in when it is stolen out of the car). A Honda Tech or ASE Certified Auto Tech would have plugged in a Memory Minder into the OBDII slot to not only prevent this, but also protect the Main ECM from resetting which could create drivability issue.
If the Honda is now registered in your name, take it to your local Honda Dealer. They should be able to pull the Radio Serial number without removing it like in the older Hondas, simply a matter of pushing the right buttons. With the Radio Serial Number, Your Proof of Ownership (Registration) and a Photo ID that matches it, either the Parts Department Or Service should be able to give you a Radio Code for it.
As for the CD ERR codes, the CD player probably is broken and will need to be sent out by Honda to a outside facility to be repaired. That will probably run between $250 to $350, plus the labor cost to remove it and reinstall it.
If you just bought this Honda, or any vehicle, I always strongly recommend having a Manufacture Dealership do at least a oil change on it and check what other services may be due, you might also discover it has Recalls that have yet to be completed that they can take care of for you. Catch the little problems before they ruin that Great Deal you just got buying it.
Strongly suggest you also join Hondas “OwnersLink”, you can find it on the Honda web site under Owners Resources links. In the future you can use this to recover your Radio code after you’ve been registered for awhile. Also keeps you notified of Recalls, Service Issues and even sends out Discount coupons (Latest is a $119 trunk cargo trays for $39, that is a Fantastic Deal).
Good Luck
Posted on May 04, 2009
stevenhurc
  • 450 Answers
SOURCE: Mech Comm Error
sounds like they may have forgotten to take out transit plugs from radio which holds cd mechanism in place when shipping unless you got a new radio thats a dud? but that may also mean dealer didnt check operation of new unit after replacement if replaced which is what usually needs to be done when this error message comes up
Posted on Aug 06, 2009
Kia rondo 2007 stereo wiring colors
2007 Kia Rondo Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Brown
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Yellow
Car Stereo Dimmer Wire: Black/Orange
Car Stereo Antenna Trigger Wire: Blue
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Orange
Right Front Speaker Positive Wire (+): Brown
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Blue
Right Rear Speaker Positive Wire (+): Black
Right
Rear Speaker Negative Wire (-): Yellow
Apr 17, 2014 | Cars & Trucks
2009 dodge ram , fm,am,cd,all work fine on radio. but when I hit satelite radio it shows channel 184 and there is nothing.
Is there audio on 184? It sounds like it just needs to be activated. Call Sirius with the SID #, and they can send a signal. Sirius' # is 888-539-7474
Jun 04, 2011 | Sirius Satellite Radio Sirius Starbase...
2009 Escape. When I purchased this year, I mostly listened to regular radio, which showed artist and title in display. Now, after playing Sirius a lot (which shows text info on display), the info no...
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
Nov 12, 2009 | 2009 Ford Escape Hybrid
Accord EX 2006...changed battery. I have the key
the radio code is a 5 digit code and the navi is a 4 digit code. if it continues to read incorrect pin then you may need to see your local honda dealer to get the correct pin
Nov 09, 2009 | 2006 Honda Accord
Putting pictures on touch screen car radio
i went to radio shack and they were very helpful. AND,it didn't cost me a penny. it was FREE!!!
Apr 05, 2009 | Sirius Audio Players & Recorders
Problem with Xact Communication XTR1 SIRIUS Radio Receiver
Turns out the radio isn't broken after all. In my research on your site I ran across a user who said he/she just plugged their radio in, turned it on and waited. I tried that and after a couple of minutes of a Sirius logo screen, then a blank screen followed by a high pitched beep the radio started playing again. I then remembered that one of the last things I input with the remote before the radio stopped working properly was mistakenly selecting an unwanted prompt on the AutoShutDown menu. When the radio finally came back on I selected Factory Default to reset all functions and now it operates properly. Thanks for the help.
Mar 28, 2009 | Xact Communication XTR1 SIRIUS Radio...
Car Audio & Video Logo
Top Sirius Car Audio & Video Experts
xxxxxx xxx
Are you a Sirius Car Audio and Video Expert? Answer questions, earn points and help others
