Question about Panasonic Televison & Video
Panasonic Vierra TC-P50S1 10 blink red light. Where do I start?
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
lovejoy91
  • 691 Answers
SOURCE: WHY MY panasonic tc-50ps14 IS BLINKING A RED LIGHT
I have a 10 blinks and 12 blinks for that set, 10 says it possible SC board, and 12 says
Unplug the TV and disconnect connector A11 from the A board. Plug in the TV and press the power switch
Does the TV power up and
stay on?
No
Yes
If the speakers wires
are not pinched,
Replace
the speaker
Replace
the A board
Posted on Jan 17, 2011
gopakumarg43
  • 75424 Answers
SOURCE: PANASONIC PLASMA TC-P50C2 The tv
Hello
Your TV is in warranty period I thinks. If so, company is liable and will repair it free fo charge. There is "repair,replace, refund gurantees. Your gurantee card and broshure will tell you that. Look at it.
For what you are going to take the risk.
Posted on Mar 24, 2011
sodeep
  • 3267 Answers
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
Posted on May 28, 2011
SD Tech
  • 14553 Answers
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
Posted on May 26, 2012
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
How do you to troubleshoot a Panasonic Vierra tc-P46G25 TV that does not turn on?
Check for bad capacitors (they'll look bloated) on the power supply board. Also check the voltages on the power supply board with your meter ; they should be etched on the board at test point location(s)
Jul 16, 2014 | Televison & Video
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
One blinking light
Use these charts to locate the problem. The burnt part may be very small and hard to see without good light.
cc1b0371-f440-4f3c-9e7b-a5baf71e0c77.jpged80d458-978c-4ec3-804c-046dd847b2b8.jpgf22dfb6d-c7ad-4b58-8c78-ba5580bcbf7f.jpg
May 25, 2013 | Panasonic TC-L42E3 - 42 Widescreen 1080p...
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
Jan 22, 2013 | Panasonic Tc-P50x1 50inch Class Viera X1...
I have a panasonic flat panel tv 1080i. 46" I think. When I press the power button, the red light comes on, then it starts blinking. And the TV never turns on, but the red standby light continues to blink....
the s1 models have been having several problems. it really depends on how many times the red led is blinking. panasonic uses a certain number of blinks to tell you what board has failed. the s1 models have just recently come out. therefore your tv should still be under manufacturer warranty. call panasonic and see if there is a servicer in your area. our company is in dallas texas. Aces Tv Service.
Nov 16, 2009 | Panasonic TC-P46S1 TV
Televison & Video Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
