I have a L5 fault on model 09F5B1BP003 model drive what is the code telling me. The motor that it is controlling will not stop when its suppose to.
  • 6 Answers
SOURCE: After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Posted on Jul 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: what is L5 code on whirlpool calypso model #GVW9959KQ0?
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
andcal
  • 182 Answers
SOURCE: hi could you please help
problem with the pump. take the clothes out, empty water (manually, if necessary), and lift edge & look underneath. The pump has a fan on the bottom. Sometimes the fan gets hung on something. If this is the case, unhang it, and the pump will work again. Sometimes, though, the pump is bad, and has to be replaced.
Posted on May 04, 2011
mendi593
  • 65 Answers
SOURCE: My Z16 york treadmill has fault L5 How can i check the speed sensor or speed controller as i have had the motor checked as ok
Call Treadmill Doctor and they will also walk you through it Free of Charge. 800-750-4766
http://www.youtube.com/watch?v=4yu7_gAOJD4&feature=g-user-u
Posted on Jul 06, 2012
jonsnell4
  • 25306 Answers
SOURCE: Kymco Super 8 Mobility Scooter with Fault code flashing twice
Probable motor brushes worn.
Posted on Apr 06, 2017
What is l5 error
Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:
A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at http://www.sportsmith.net/supportsearch.aspx we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
Nautilus t714 error code L5. Can you tell me what this error code means? Thank you. Tim
Dear Sir:
I just want to say to L5 means many things.
1)You must check socket wiring from upper board(display) vs lower board(controller motor board)
2)Short circuit in capacitor(EMI) in input circuit or Short circuit in Main Motor Test.
3)Faulty Controller Motor Board-Replace.
4)Realign Sensor Speed Motor and clean or Replace
Since the Controller Motor Board control 90% function in Treadmill , will the most probably cause, after you did Test all Step before mentioned. And strong concluded the Lower Board is Faulty.
sincerely.
If you need further assistance, please reach me.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
Nov 22, 2011 | Exercise & Fitness
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error E5 or L5???
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
What is L5 code on whirlpool calypso model #GVW9959KQ0?
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stops working and the light flashes L5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
THEREIS A FAULT CODE L5 COMING UP ON MYT102HERRITAGE TREADMILL CAN YOU HELP
L5 or LS is short for Low Speed error. It basically means that the speed sensor is not picking up a signal. Unfortunately its a pretty vague error code and can be caused by several different problems. First you have to determine whether or not you have belt movement. If you have a LS with belt movement you know that it is related to the speed sensor itself (or the MCB motor control board - the part of the MCB that handles speed sensing function). If you are getting an LS without belt movement you have to check to see if you have power output from the MCB. If you have no power output, check fuses, if fuses are good, you will need the MCB replaced. If you have sufficient output its drive motor related. Aside from a problem with the drive motor, it is possible that another factor is stopping the motor from turning (ie locked up roller bearing, foreign debris, etc.) If it is a case of
faulty electronics the next question is, is to figure out what caused it to fail. Most MCBs don't fail on their own, something else usually causes them to fail. The bottom line: The LS error can be
complicated and should really be inspected by a professional to full assess the issue. What I am saying is call the manufacturer and if it is under warranty send the treadmill back.
Jun 06, 2010 | York Exercise & Fitness
L5 show in display and won't work in calypso washer
ss13679,
I believe your code is actually 'LS'. This codes shows up when the controller cannot detect the lid switch opening and closing properly. This error code may also be used if there is a diagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if you press the start key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Your lid switch may be bad. Click here for some help. Also it looks lik this: click here
Hope this helps. Please give me a vote!
-samson39
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
KENMORE CALYPSO WASHING MACHINE
Jan 26, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
