A set comes on that is not suppose to come. Stays on as it goes through other sets
My Samsung Intensity cell wont turn on, how can i fix it?
Putting the Phone back to factory settings may be helpful to resolve this issue.
I would suggest you to take the device to the closest service center and get it flashed
Mar 15, 2015 | Cell Phones
Intex krystal pump systems how do i set the timers to set the interinterv
Nancy... This is how I have mine set up... I have a cheap Home Depot Timer that I use for the Filter/Pump the comes on at 6:00am in the morning and goes off at 12:00 pm... This Timer is very simple to use... For the Salt water System, For the first time I turned it on was at 6:30 AM (before work) and set it for 5 hours... Once is has completed the 5 hours, it will go into Sleep Mode and automatically start 24 hours later, so in my case, it will start the next day at 6:30 am... So i have have my Filter/pump come on 1/2 hour before the salt system comes on and it goes off 1/2 hour after the salt system goes off...
Hope that helps.
Dan
May 19, 2013 | Intex Automatic Salt Water System for ...
On my Duet Steam washer that I recieved a week ago, none of the cycles or options on the right side of the settings dial lights up green. When I turn it one setting to the right, the light stays on...
this is only a week old, you should call the repair facility or consult your owners manual to be sure that the unit is or isn't doing what it is supposed to do. This should still be under warranty, so the place you purchased the unit from should be able to help you the best.
Joe
Aug 29, 2011 | Washing Machines
My dash light for brakes stays on and comes on while driving , lfluid level is fine light comes and goes
the same light indicates the parking brake is set, wiggle the brake around and see if the light goes on/off
Oct 08, 2010 | 1998 Volkswagen Cabrio
Element is staying off too long
element should cycle a little longer than that i think 2 min then cycles high limit thermostat u checked could be reading wrong when its gets to certain temp that thermostat opens up so wont get so hot and catch on fire .. take thermostat is the smallest one is your high limit thermostat probably the one going bad
Jul 12, 2009 | Dryers
SL5618 Heath Zenith lights on all the time and during the day...
i've install many automatic lights- none of them work 100% There are patterns with most of them (flip switch on,off,on) to make lights on constantly, but they should all turn off when you turn the switch off.
Apr 07, 2009 | Hardware & Accessories
Ingnition stays on after oven lights
HI thanks for your question. the igniter is suppose to stay on , all the way through the cycle. only goes out when desired temp is reached. when more heat is required, the igniter comes on again, and stays on. thanks the appliance doc. if happy with my answer. please rate my answer. thanks
Oct 14, 2008 | Kitchen Ranges
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
