Question about LG Televison & Video
My lg 42 in tv wont change channels after been on awhile
Have dish receiver an remote have replaced them 3 times so its not that an doesn't happen in other 2 rooms I can turn it off an back on an can chanel 1 time im disable so tv is my life an cant afford 2 buy new 1
ice man
  • 68 Answers
SOURCE: after programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Posted on Mar 25, 2007
SOURCE: Dish 20.0 IR Remote works for awhile then it
I MAY have a solution!! We too have the VIP722 Dish Network receiver. Ours is the "K" model. I called the place where we purchased the TV and they said that the "brightness" on the TV may need to be turned down. He walked me through this, and it worked. The remote WORKS now!! Our TV is a 40" Sony Bravia that we purchased a couple of months ago. Evidently at night, the TV was so bright in the room, it interfered with the Infared Remote control. By turning down "off" brightness detector on the TV, the IR remote was able to send the signal to the receiver. Our TV is on a cabinet and the receiver is directly underneath on a shelf. I hope this solves your problem and anyone else's that may have this problem with the remote.
Posted on Mar 18, 2009
  • 273 Answers
SOURCE: How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
Posted on Jun 03, 2009
  • 136 Answers
SOURCE: lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Posted on Aug 08, 2009
SOURCE: dish remote wont change channels
make shure it is turned on the sat setting
Posted on Oct 06, 2009
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
TV 1 does not pick up Dish, scanned but doesn't show Dish
1) change the new batteries
2) Clean the contacts batteries very well
3) retight the springs contact for better contacts batteries
4) Open the remote and clean the keypad with special spray contacts cleaner.
Otherwise you must go to the repair shop.
download again the code: www. fitness.manualsonline.com
God bless you
May 23, 2012 | DISH Network IR Remote Control
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
My remote doesn't work, it won't change the channels
It sounds like the remote would need to be address to the receiver. This needs to be done from the main TV location, and I have listed the steps below!
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
Hope that helps!
Tommy Faust
DISH Network
Jul 04, 2011 | DISH Network 32 Ir 137180 Remote 5900 3100...
My dish network duel feed remote will quit working the dish reciever after about 15 miniutes or so,however it will still turn tv on and and off. if I shut the reciever down for a while it may or may not...
Hi pappy63my name is Mike Houston of DISH Network and there are some steps that will getyour DISH Network remote to change the satellite channels. The first thing youwill need to do is press the System Info button on the receiver or pull out thesmart card from the receiver, with the remote press and release the SAT buttonand press the Record button and you will see the number in the white boxchange. I will leave a link to help with these steps. http://www.dishnetwork.com/SupportSection/remote-setup
Feb 11, 2011 | DISH Network IR Remote Control
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
Cant make the remote connect to the TV. Got it set up to the TV. Wont change channels and no guide will come up.
Hi there, Tommy Faust with DISH Network Executive Offices here. It sounds like the remote is not programmed to the receiver. I have included steps below to get that programmed.
1. Go to the System Information screen and check the number under Remote Address.
2. Hold SAT until all buttons on top of the remote light up.
3. Let go and while SAT is blinking enter a number between 1-15 on the number pad and press #
4. Press record 3 times and see if the number changed.
Sep 21, 2010 | DISH Network IR Remote Control
No picture just sound thru dish network
There are a few reasons that this could happen. The main reason would be that the tv is on the incorrect channel or input. You will want to make sure that if you are at TV1, the channel is on 3 or 4, and an input if needed, such as VIDEO 1 or 2. If at TV2, the channel needs to be on 60 or 73. Cabling is another reason this could be. You want to make sure that if you are at TV1, all cables going from the receiver to the TV are connected on the back of the receiver at the green TV1 location. For TV2, the cable needs to be connected to the HOME DISTRIBUTION output on the back of the receiver.
Becki Barned
DISH Network Customer Service
Jun 01, 2010 | LG 52LG50 52 in. LCD HDTV
Dish remote wont change channels
Oct 05, 2009 | DISH Network IR Remote Control
Channel keeps changing
If you are using the remote to change channels it sounds like either the front of the remote and/or the receiving “eye” on the TV need to be cleaned, OR (more likely) the button on the remote is sticking. It is actually a button that pushes on a membrane under the entire remote panel. This is generally caused by some sticky liquid (like Coke) getting spilled on it. If you are brave enough, you can take the remote apart and clean it with denatured alcohol. Otherwise you need to replace your remote. If possible borrow a universal remote and see if it still happens. If that doesn’t fix it you have a bad IR receiver and/or a serious internal problem.
Jan 29, 2008 | LG 32LX1D 32 in. LCD Television
Televison & Video Logo
24 people viewed this question
Computer Repairing
Computer Repairing
