Question about Home
HOW TO GET BACK OFF OF THE OUTSIDE TRANSMITTER TO REPLACE BATTERIES THEY ARE SOLAR BATTERIES DONT KNOW HOW TO GET THE BACK OFF
  • 17,247 Answers
There is no such thing as a 'solar battery' :>) All solar powered electronic devices have a solar panel which creates DC power which charges a normal lithium ion, or nickel metal hydride battery. Normally, the battery will last the life of the appliance. I am guessing you are talking about some type of weather station, or perhaps a security device, you don't say? If there are no screws, there are probably internal clips that lock together when pressed shut during manufacture. The can be released using a tool called a 'bludger', which presses in the right place and unlocks the catch. The problem is knowing where they are? If you know someone who works at an airport or a hospital, you can get then to x-ray it. Or you can just hope for the best and use a flat bladed screwdriver. Glue it back together afterwards with superglue.
Posted on Aug 09, 2017
4 Suggested Answers
  • 7 Answers
SOURCE: changed batteries
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Posted on Dec 19, 2008
ariftariq123
  • 56 Answers
SOURCE: Outside Temp not displaying on clock. 2nd
may the the sysrem is dameged besacue the same problem was with mine there was a resister was dameged i changed it i work perfect.
Posted on Nov 20, 2009
  • 27 Answers
SOURCE: traxxas blast loeses control outside 2-3' range
dude traxxas are garbage! sorry
Posted on Jun 30, 2012
SS 5010 not sensing outside temperature. I replaced the batteries in the transmitter and pressed the TX. However, the display inside just keeps blinking. I can see the inside temperature.
Inside temp is separate from outside...no connection whatsoever. If the outside transmitter has new power and fails, it may have gotten wet inside and may be rendered useless. Replace with a new outdoor transmitter.
Jan 31, 2018 | Measuring Tools & Sensors
The outside temperature has stopped displaying. I bring the transmitter inside and it displays. what is wrong?
Weak batteries, most likely. Replace the transmitter batteries with fresh ones.
Mar 17, 2016 | Home
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Wa 1070t willnot transmit signal from the outside sensors to the display
I have a WA-1070T with same problem
brand new would not communicate
look very carefully at the positive end of the battery connections in the outdoor transmitter
One of the two batteries were not making a connection
I had to cut out a small piece of plastic that interfered with battery alignment
As soon as batteries are installed in remote transmitter you will see a red LED flash a few times
After I made this correction everything worked
May 26, 2014 | dr. Tech Solar Transmitter Wireless...
Blank screen for wind --- new batteries in everything
Did you press the reset on the solar transmitter after you replaced the batteries? It is left of the NiCAD pack if the AA batteries are on the right. If after pressing reset, and you are using a WMR 938, and still not receiving, press and hold the "channel" button for 5 seconds on your monitor to re-register the signal from the transmitter.
Dec 06, 2013 | Oregon Scientific STR938 Solar...
I have inherited a IT-915 MHz wireless temp. station--the batteries in outside sensor were taken out but still in box-can i put them back in at this time to reset the sensor and how to set them ?
You shoud use new batteries because you dont know how old the ones that are present are. You should also use lithium battteries in the weather station sensors because they last longer and have better low temp response. The batteries should have marks on them that correspond with the marks inside the sensors.
Feb 23, 2013 | Weather Channel It 915 Mhz Solar Powered...
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
We replaced the batteries on our SIO SCAN temp transmitter but it still will not register the outside temperature--what do I do?
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
Dec 08, 2009 | SkyScan 86709 Atomic Wall Clock
The solar eyes dont light up anymore
Check the rechargable batteries insode of the decoy. The solar panels recharge the batteries so that they can supply energy to the lights at night. The batteries have a limited lifespan and need to be replaced every couple of years. Replacing the batteries ought to bring your decoy back to life. Enjoy!
Aug 04, 2009 | Nurserypro - Floating Solar Alligator...
Changed batteries
Also,
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
29 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
