Question about Garden
My Ariens 927-046 has not forward motion below 3 on speed sel.
My Ariens 927-046 runs great as long as I have the speed control at 4 or above. Anything under 4 and the forward motion is very slow to almost a stop. I have replaced the friction disk and the clutch tension spring to no avail. Mowing with the speed selector at 4 is too fast for anything but the most wide open spaces
  • reed_g Jul 27, 2009
    I cannot fine a speed selector relay in the parts list. This model has manual speed selection. I will contact Airens
    I assume I do not have to pay for this solution since it really is not a solution.
    The solution was not even a part on the parts list. The recommendation to call Airens should be a charged fix.
    President:
  • 2,777 Answers
It sounds like the speed selector's relay is actually the issue. If it works fine at 4 or above then I certainly wouldnt think the friction disk or clutch tension spring is the culprit. I am familiar with this model but have never seen anything like this problem. Have you called Ariens? They have free technical support on their products, I believe for life, so they should be able to confirm my suspicion. Their number is 920-756-2141
Give them a try, if they are no help please get back to me here and we can try a few more things.
Posted on Jul 27, 2009
  • Tim Grayson
    Tim Grayson Jul 27, 2009
    I am not sure how they will determine that on fixya's side as far as the payment is concerned. I would definitely give Airens a try, if you could come back and rate my answer / put whether or not I was helpful I would really appreciate it. Then you may want to contact fixya regarding the billing.
    Thanks
    Tim
Hi zx6 r f3 runs great above 15 hundred revs but only on 3 on tick over
Hi, Colin and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
97 ZX6R Turns over but won hold idle
http://www.kawiforums.com/archive/index.php/t-81966.html
Fix It Friday motorcycles
1995 1997 Kawasaki Ninja ZX 6R Service Manual ZX600 F1 F2 F3 Moto Data...
Aug 21, 2016 | Motorcycles
Tip
Detroit Diesel Fault Codes
Code Description DDEC V Circuit
11 P 187 4 Chain PTO. Short circuit in the power
11 P 187 7 control system PTO wrong answers
12 P 187 3 Chain PTO. Short circuit in the ground
13 P 111 4-level circuit antifreeze. Short circuit in the ground
13 P 111 6 second-level circuit antifreeze. Short circuit in the ground
14 P 52 3 circuit coolant temperature intercooler. Short circuit in the power
14 P 110 3 circuit temperature antifreeze. Short circuit in the power
14 P 175 3 Chain oil temperature. Short circuit in the power
15 P 52 4 circuit coolant temperature intercooler. Short circuit in the ground
15 P 110 4 circuit temperature antifreeze. Short circuit in the ground
15 P 175 4 Chain oil temperature. Short circuit in the ground
16 P 111 3-level circuit antifreeze. Short circuit in the power
16 P 111 5 second circuit level antifreeze. Short circuit in the power
17 P 51 3 Throttle position circuit failed high
17 P 72 3 Bypass position circuit failed high
17 P 3 354 Relative humidity sensor circuit failed high
18 P 51 4 Throttle position circuit failed low
18 P 72 4 Bypass position circuit failed low
18 P 354 4 Relative humidity sensor circuit failed low
21 P 91 3 TPS circuit failed high
22 P 91 4 TPS circuit failed low
23 s 65 3 Oxygen content circuit failed high
23 P 174 3 Chain fuel temperature. Short circuit in the power
24 s 65 4 Oxygen content circuit failed low
24 p 174 4 Chain fuel temperature. Short circuit in the ground
25 no codes
26 s 25 November Aux. shutdown # 1 active
26 S 61 11 Aux. shutdown # 2 active (Incorrect SID. subject to change)
27, p 105 3 circuit temperature in the reservoir. Short circuit in the power
27 p 171 3 Ambient air temp circuit failed high
27 p 172 3 Air temp, circuit failed high
28, p 105 to 4 Chain manifold temperature. Short circuit in the ground
28 p 171 4 Ambient air temp circuit failed low
28 p 172 4 Air temp, circuit failed low
29 p 404 4 TCO temperature circuit failed low
29 p 351 4 TCI Temperature circuit failed low
31 S 51 3 Aux. Output # 3 open circuit (high side) S3
31 S 51 4 Aux. Output # 3 short to ground (high side) S3
31 S 51 7 Aux. Output # 3 mech. system fail S3
31 s 52 3 Aux. Output # 4 open circuit (high side) T3
31 s 52 4 Aux. Output # 4 short to ground (high side) T3
31 s 52 7 Aux. Output # 4 mech. system fail T3
32 S 238 3 SEL short to battery B1
32 S 238 4 SEL open circuit B1
32 s 239 3 CEL short to battery B2
32 s 239 4 CEL open circuit B2
33 p 102 3 Boost pressure circuit failed high
34 p 102 4 Boost pressure circuit failed low
35 p 19 March Ext range oil pressure circuit failed high
35 p 100 3 Chain oil pressure. Short circuit in the power
36 P 19 April Ext range oil pressure circuit failed low
36 P 100 4 Chain oil pressure. Short circuit in the ground
37 P 18 March Ext range fuel pressure circuit failed high
37 P 94 3 Chain fuel pressure. Short circuit in the power
37 P 95 3 Fuel Filter Restriction circuit failed high
38 P 18 April Ext range fuel pressure circuit failed low
38 P 94 4 Chain fuel pressure. Short circuit in the ground
38 P 95 4 Fuel Filter Restriction circuit failed low
39 S 146 2 Mechanical error EGR valve
39 S 146 12 Mechanical error EGR valve
39 S 146 return valve 7 does not meet the exhaust
39 S 147 2 turbocharger control mechanism does not respond
39 s 147 12 turbocharger control mechanism does not respond
39 s 14 147 current returns exhaust gases enough
39 S 147 11 turbocharger control mechanism does not respond
39 S 147 7 turbocharger control mechanism does not respond
41 S 21 0 Too many SRS (missing TRS)
42 S 21 January Too few SRS (missing SRS)
43 p 111 1 Low coolant level
44 p 52 0 ntercooler coolant temp, high
44 p 105 0 temperature in the reservoir above the norm
44 p 110 0 antifreeze temperature above normal
44 p 172 0 Air inlet temp, high
44 p 175 0 Oil temperature above normal
45 p 19 January Ext range oil pressure low
45 p 100 1 Oil pressure below normal
46 p 168 1 Low voltage batteries
46 S 214 1 RTC Backup Battery Voltage Low
46 S 232 1 Sensor Supply Voltage Low A3 & W1
P 0 47 18 Ext range fuel pressure high
P 47 94 0 The fuel pressure above normal
47 p 0 102 Turbo boost press high
47 p 106 0 Air inlet pressure high or TCBV diff press high
47 p 164 0 Injection control pressure high
48 p 18 January Ext range fuel pressure low
48 p 94 1 fuel pressure below normal
48 p 106 1 Air inlet pressure low
48 p 164 1 Injection control pressure low
48 p 351 1 TCI Temperature below range
48 p 404 1 TCO Temperature below range
48 p 411 1 EGR Delta pressure low
48 p 412 1 EGR Temperature low
49 p 351 0 TCI Temperature above range
49 p 404 0 TCO Temperature above range
More Fault Codes here Detroit Disel DTC
on Dec 20, 2016 | Cars & Trucks
Husqvarna 4623 zero turn mower will not move
Maintanance - How to purge Hydraulic drive system Published 01/13/2010 11:56 AM ' Updated 06/02/2015 02:52 PM
How do I purge the hydraulic system?
Hydrostatic transmissions use oil, under pressure, to provide movement for the tractor. The fluid is pressurized with a pump inside the transmission. If any air is in the fluid, the pump will try to pressurize air. This condition is known as cavitation, and is detrimental to the pump since it allows the pump top operate dry. When the pump cavitates it is not pressurizing any fluid, so the transmission is not able to provide the movement needed.
If your mower is new, or has been stored for a long period (longer than 2 months) the transmission needs to be purged before use. Also, if you experience loss of drive, or slower response, then the transmission should be purged first.
The following procedure will remove trapped air inside the transmission(s).
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
Aug 06, 2016 | Husqvarna Garden
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
How to set clock jvc kw-xc770 car stero
1 Press SEL for more than 2 seconds. One of the PSM items appears on the display. 2 If "PSM CLOCK H" does not appear, press fast forward and up or fast backward and down repeatedly until it appears. 3 Turn the control dial to adjust the hour. 4 Press fast forward and up or fast backward and down until "PSM CLOCK M" appears on the display. 5 Turn the control dial to adjust the minute. 6 Press SEL again to finish the setting.
http://www.jvc.ca/manuals/KW-XC770.pdf
May 05, 2011 | JVC KW-XC770 CD / Cassette Player
How do you set the clock
These are generic instructions for a JVC car stereo:
1. 1. Hold "SEL" button
2. 2. Select CLOCK H or CLOCK M with the fast forward button or fast backward button.
3. 3. Adjust item with wheel
4. 4. Finish by clicking on "SEL" button
5.
Manual can be downloaded at:
http://support.jvc.com/consumer/product.jsp?categoryId=CATG0004&archive=true
May 05, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do i turn off demo mode? And set the clock?
  • Press and hold (SEL) button
  • Then turn the control dial to set "Demo/Link" to off
  • Setting the clock
  • Press number button 4 (Clock). "Clock Hr" (hour) appears. Then, turn the control dial to adjust the hour.
  • Press the >>' /\ (fast forward button) to select "Clock Min" (minute). Then, turn the control dial to adjust the minute.
  • Press the >>' /\ (fast forward button) to select "24H/12H". Then, turn the control dial to select "12Hours" or "24 Hours" time display mode.
  • Exit from setting by pressing the (SEL) Button
Hope that helps, don't forget to vote.
Nov 16, 2010 | JVC KD-G820 CD Player
Demo problem
Here is how to shut off the demo:
1) Press and hold the SEL button for several second until DEMO appears on the display. Release your finger from the SEL button.
2) Using the Volume control knob, turn left or right to turn on/off DEMO.
3) Press and release the SEL button to accept.
Setting the clock:
1) Press and hold the SEL button for several seconds until the DEMO shows on the display.
2) Use the right search arrow in the 4-way button just above the SEL to get to the clock hour. Do not use the up or down key.
3) Turn the volume control knob to select the hour.
4) press the right arrow once more to get to the clock minute.
5) Turn the volume control knob to select the minute.
6) When finish, press and release the SEL to accept.
Good luck
Sep 02, 2007 | JVC KD-G230 CD Player
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
