SOURCE: portable dvd replacement charger
Anyone needing to replace parts for a Durabrand item, I located this website after many hours of research. They have a number of replacements parts and they aren't that expensive either. Good Luck
http://www.1800customersupport.com/products.aspx?cid=4
SOURCE: 7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Durabrand Technical Support, Parts and Accessories
http://1800customersupport.com/
Also the support division of these companies:
Audiovox
Durabrand
ILO
Kawasaki
Lextron
Magnavox
RCA
Trutech
V7
Venturer
The actual manufacturer:
Alco Electronics
Hong Kong
Company : Alco International Ltd.
Address : 11/F, Zung Fu Industrial Building, 1067 King's Road, Quarry Bay, Hong Kong.
Telephone : (852) 2880 0698
Fax : (852) 2880 0858
E-mail : [email protected]
Website : http://www.alco.com.hk
EUROPE
Company : Venturer Electronics Europe Ltd.
Address : Unit D, Bourne Park, Cores End Road, Bourne End, Bucks SL8 5LS, United Kingdom.
Telephone : (44 1628) 527 757
Fax : (44 1628) 527 794
http://www.alco.com.hk/main/
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
SOURCE: Accurian 7-inch dual screen portable dvd player apd-3911
We had the same problem. Since ours was off warranty, I took the back off (several small screws) and lubricated with some fine oil the track (two silver rods about three inches long) upon which the lens slides back and forth. It can be tricky to get it apart and back together again. I also manually slid the lens carrier so that it was in the middle, partway away from the center spindle. Now ours works fine. I think the problem was that the lens carrier doesn't slide very well or gets stuck on the track rods.
