Central air unit runs but no cold air from the start. after a while coil freezes up solid.
  • 158 Answers
Maybe dirty air filter or slow fan motor or if the ice build-up does not cover whole of coil it maybe short of gas due to minor leak.
Posted on Jul 27, 2009
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
Freezer not cooling properly. The compressor comes on the fan is constantantly running and cold air is coming through the vent in the freezer the meat etc freezes but not as solid as before
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2011 | Kenmore 63014 Top Freezer Refrigerator
I have a Coleman Central Air Conditioner/Heat Pump. On the cooling mode the coils inside the unit in the basement continue to freeze up causing no air flow. I relpaced the filter thinking it might have...
The most common reason for freezing up is 'air flow,' and since you've already changed your filter - have you checked out the coil (the one that cold air comes from) to see if it's clean? If the filter you changed was really 'bad dirty' then it's a good bet the coil could be dirty also - thus restricting the air flow.
If you're satisfied that the coil is clean - about the only other thing it could be - is 'low on refrigerant,' which of course will take a Service Tech to find the leak, repair it and then re-charge the unit with refrigerant.
One other thing you might think about - are you running the blower motor on 'low speed?' If you are then put it on 'high' and see what happens.
Again, the most likely cause of your problem is air flow or 'low load,' - so I would really look hard for an air flow problem of some sort.
hope this has helped a little
Jun 20, 2010 | Heating & Cooling
Frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Jun 06, 2010 | Frigidaire Heating & Cooling
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Central air unit
Make sure you let the blower run for a while after it freezes to make sure there is no more ice. Then run the unit. Check the refrigerant lines the large copper line that has insulation on it should be cold to the touch. If it runs for 10 minuits and is barely cold or warm you are low on refrigerant. If its starts out nice and clod then check your filter and retun ductwork for blockage you should not have noisy return air vents or that can indicate you have too small a return.
Also are the outdoor unit and indoor coil a match? Same tonage?
Is the furnace big enough to handle the tonage? (fan size)
Aug 17, 2008 | Coleman Propane Forced Air Heater...
No cold air
Freezes up is only caused by either low on freon or low aiflow across the indoor coil, which could be caused by dirty or blocked filter ,,dirty fan blower wheel or pluged coil.
May 27, 2008 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
185 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
