SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at [email protected] and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
SOURCE: troy bilt pony will not start. replaced 20 amp fuse and battery
OK -- Here's what to do:
TROY-BILT PONY LT CRANKING CIRCUIT TROUBLESHOOTING
NOTE 1: The following tests are to be made with the parking brake applied and the PTO disengaged unless otherwise specified.
NOTE 2: These tests need only be made until the cause of the problem is located. The entire process need not be completed if the problem has been resolved.
NOTE 3: Refer to the wiring diagram below for understanding of all tersts.
NOTE 4: Wiring Diagram references to Key switch A1 and L terminals refer to the same terminal.
1. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the battery positive terminal. The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 2.
b. If YES, go to Step 3.
2. Connect a DC voltemeter directly across the battery. The voltmeter should read at least 12.6 VDC.
a. If NO, charge or replace the battery.
b. If YES, check and repair/replace the following items as required, then repeat Step 2 test. If YES on retest, go to Step 3.
-- battery negative cable condition
-- battery negative cable connections at the battery
-- battery negative cable connections at the tractor frame
3. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key swttch "B" terminal (Circuit #97 - red/white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 4.
b. If YES, go to Step 8.
4. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay BAT terminal (Circuit #94 - heavy red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 4 test. If YES on retest, go to Step 5.
-- battery positive cable condition
-- battery positive cable connections at the battery
-- battery positive cable connection at the starter relay
b. If YES, go to Step 5.
5. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder BAT terminal (Circuit #92 - red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 5 test. If YES on retest, go to Step 6.
-- Circuit 92 wire condition
-- Circuit 92 wire connection at the starter relay
-- Circuit 92 wire connection at the fuse holder
b. If YES, go to Step 6.
6. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder protected circuit terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 6 test. If YES on retest, go to Step 7.
-- 20A fuse condition
-- fuse holder condition
-- fuse holder wire connections
b. If YES, go to Step 7.
7. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "B" terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 7 test. If YES on retest, go to Step 8.
-- Circuit 97 wire condition
-- Circuit 97 connection at fuse holdser
-- Circuit 97 connection at key switch
8. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "S" terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 8 test. If YES on retest, go to Step 9.
-- key switch assembly
b. If YES, go to Step 9.
9. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #80 terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 9 test. If YES on retest, go to Step 10.
-- Circuit 80 wire condition
-- Circuit 80 connection at key switch
-- Circuit 80 connection at parking brake switch
b. If YES, go to Step 10.
10. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at
least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 10 test. If YES on retest, go to Step 11.
-- parking brake switch assembly mounting and adjustment
-- parking brake switch assembly condition
b. If YES, go to Step 11.
11. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 12.
-- Circuit 70 wire condition
-- Circuit 70 connection at parking brake switch
-- Circuit 70 connection at PTO switch
b. If YES, go to Step 12.
12. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 12 test. If YES on retest, go to Step 13.
-- PTO switch assembly mounting and adjustment
-- PTO switch assembly condition
b. If YES, go to Step 13.
13. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least
+12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 14.
-- Circuit 60 wire condition
-- Circuit 60 connection at PTO switch
-- Circuit 60 connection at starter relay
b. If YES, go to Step 14.
14. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay MOT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, did the relay make a single heavy "click" noise?
1. if YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
2. If NO, connect a DC voltmeter DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter relay frame. With the key held in the START position, the voltmeter should read a maximum of +0.1 VDC.
a. If YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
b. If NO, check and repair/replace the following items as required, then repeat Step 14 test. If YES on retest, go to Step 15.
-- starter relay mounting
b. If YES, go to Step 15.
15. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter motor BAT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 15 test. If YES on retest, but the starter motor does not engage, go to Step 16.
-- Circuit 93 cable condition
-- Circuit 93 cable connection at starter relay
-- Circuit 93 cable connection at starter motor
b. If YES, but the starter motor does not engage, go to Step 16.
16. Connect a DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter motor frame . With the key held in the START position, the voltmeter should read a maximum of +0.2 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 16 test. If YES on retest, but the starter motor does not engage, go to Step 16b.
-- starter motor mounting to engine
-- engine mounting to tractor frame
b. If YES, but the starter motor does not engage, replace the starter motor.
REFERENCE PART NUMBERS PER WIRING DIAGRAM:
Note that your specific tractor may use differnt part numbers. You can obtain a Parts List specific to your tractor online, at no charge, from Troy-Bilt at www.troybilt.com -- your full model number and serial number are required.
Key Switch 725-04228 (common alternatives are 925-04227B & 925-04659)Parking Brake Switch 725-1657A (common alternative is 725-04363)
PTO Switch 725-1657A (common alternative is 725-04363)
Starter Relay 725-04439
Also note that the starter motor is an engine manufacturer supplied part.
