Question about Dell (E210882) Motherboard
E210882 socket type 775, PCIe, DDR2 - Will not turn on
This is my 8th build. I got this mobo/cpu/psu from a guy I work with. Put them in a custom case with hdd, dvd, ram, etc., but I don't know the front panel pin locations for this board, the pins are not labeled. I have the green power light on the mobo, and I've tried the power switch wire on every combination of pins possible and can't get this thing to power up. I've swapped power supplies that are working in my other PCs, and still nothing. I cranked this mobo up in this case before to check all components before I started modding it and it cranked up. Since I removed the power connections and front panel pins, I can't get it working. Anyone have any ideas? I'm clueless.
  • 3 more comments
  • Joey
    Joey Jul 27, 2009
    I know the pin assignments for the front panel, I just don't know the pin locations on the mobo. They aren't labeled, which pin is #1, 2, 3, etc.?
  • Joey
    Joey Jul 27, 2009
    That isn't even remotely similar to the header on my mobo. There are no markings on my header other than color coding, which is pretty much useless. It has no numbers or anything. There are only 9 pins on my header. The color coding is red, green, blue, yellow, with blue having three pins and is on top row, left. I'm trying to find the actual part number or a pic of my header, but no luck so far. Sorry for so little info.
  • Joey
    Joey Jul 27, 2009
    http://www.intel.com/support/motherboard...
    Here's an image of the header for my board. Now that I know where the wires are supposed to connect, guess I just have to start swapping parts around. I just have no idea what the problem is though. This thing powered up before in this case with this same psu. I put another board in the case for a few days, put this one back in and now it won't run? Driving me crazy. I HATE DELL!
  • Joey
    Joey Jul 27, 2009
    Finally found the real part number for my board after a week of searches. It's a DG33FB.
  • Joey
    Joey Jul 27, 2009
    The case I'm trying to install this board in is the Apevia X-Gear model ATXB5KLW-AL
  • Dell Master
  • 4,806 Answers
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
Posted on Jul 27, 2009
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Jul 27, 2009
    The board should have a connector panel header on it that looks similar to this >>>>>
    look for the pins marked with #1
  • Lee Hodgson
    Look at the connectors >>>>>>>
    6-8 (red) is your power sw
    2-4 (green) is your power LED
    1-3 (yellow) is your HDD LED
    5-7 (purple) is your reset sw
    black is not connected
  • Lee Hodgson
    If the power connectors are not marked in the new case then track the connector wires back to the front of the case.
    The power switch leads back to the on/off button
    The reset switch leads to the reset button and so on, is should be easy enough to work out from there.
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
When try to make the M/B on it just run the cpu fan and power drops instantly ?
That means the PSU( Power Supply Unit ) is not giving enough power.
Check the wattage of your PSU, it should be 500 watts or more to power up that MoBo or the PSU your using is not working anymore.
Hope that helps you out!
Sep 13, 2011 | Biostar GF7100P-M7S Motherboard - v6.0,...
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Motherboard no power
In this order:
check PSU is working ( fans run in the psu), test with another psu installed,
See of there is a green LED lit on the mobo
Check capacitors are not bulging or leaking and there are no signs of burned circuit traces on mobo
remove ram and try booting see if you get power to the cpu fan
try bypassing the PW switch and touching the PW terminals on the fpanel header to eliminate swith problem.
If that fails, suspect dead mobo
Jan 11, 2011 | EliteGroup ECS P4M900T-M2 Socket 775...
An intel celeron D socket 775 ddr2 motherboard for w3560 desktop
yes a mid sized. and it is call mATX for the form factor.
-socket 775
-DDR2
-PCIE
-mATX
Jun 05, 2010 | eMachines W3506 PC Desktop
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
Will this motherboard work?
in short, no
her cpu is a 775 socket, yours is 478 socket
her ram is ddr2, your is ddr1
would have to downgrade her parts to use your motherboard
Jun 08, 2009 | Dell Dimension 3100 PC Desktop
Connecting my PSU to my Motherboard
The bare essentials to start a computer are PSU, Motherboard, CPU, RAM and Video.
Its possible the PSU arrived DOA. Though I've only had 2 DOA PSU's in the 15 years I've been building custom computers.
Hope this helps.
Mary
May 21, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Asus P5GD1-FMS 775 Intel 915GExp. need help..
v i i i
P5GD1-FM specifications summary
(continued on the next page)
CPU
Chipset
Front Side Bus
Memory
Expansion slots
Storage
High Definition
Audio
LAN
USB
IEEE 1394
BIOS features
Rear panel
LGA775 socket for Intel® Pentium® 4/Celeron processor
Compatible with Intel® Performance Universal FMB 2005
processors
Supports Intel® Hyper-Threading Technology
Northbridge: Intel® 915P Memory and Controller Hub (MCH)
Southbridge: Intel® 82801FB ICH6
800/533 MHz
4 x 184-pin DIMM sockets support unbufferred non-ECC
400/333 MHz DDR memory modules
1 x PCI Express x16 slot for discrete graphics card
3 x PCI slots
Intel® ICH6 Southbridge supports:
- 2 x Ultra ATA 100/66/33 hard disk drives
- 4 x Serial ATA hard disk drives
Realtek® ALC861 8-channel CODEC with Jack-sensing
and Universal Audio Jack (UAJ®) technology
1 x Optical S/PDIF out port
Realtek® RTL8101L LAN controller
Supports up to 8 USB 2.0 ports
T1 controller supports:
- 2 x IEEE 1394a ports
4 MB FWH, AMI BIOS, Green, PnP, DMI2.0, WfM2.0,
ACPI 2.0a, SM BIOS 2.3
1 x Serial port
1 x IEEE 1394a port
1 x LAN (RJ-45) port
4 x USB 2.0 ports
8-channel audio ports
Nov 24, 2007 | Computers & Internet
Dell (E210882) Motherboard Logo
3,195 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
