Question about Dell Dimension 3000 PC Desktop
When the computer is plugged in it doesnt work. The datech fan doesnt work. The front of the computer displays an orange light instead of green. If I replace the fan will this correct the problem
  • Albert Benjamin
    Albert Benjamin May 11, 2010
    Is this a brand new computer or have you had it for awhile ? Also ,are you making contact with carpet a lot when you use it ? Is your computer plugged into a surge supressor ? Have you had a "brownout" ,"blackout" or thunderstorm in your area around the time the computer stopped working ? Sounds like a faulty power supply and / or motherboard.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
Replacing the fan as far as I know should not cause a light change but instead the computer would get hot shutdown every time he got too warm the orange light usually signifies a hardware problem. If you have opened your computer before you might have accidentally disconnected the hard drive or one of the cables from the motherboard. If the hard drive is disconnected that usually will get an orange light or if a ram chip is missing or not in all the way does a computer beep when you turn it on
Posted on Jul 27, 2009
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jul 14, 2014 | Soyo Computers & Internet
Desktop turns on , doesnt beep, black screen, with orange light in front. instead of green
So if I understand you correctly when you turn it on you get the oraange light on the front, the sound of the fans turning but no beep and no video output?
If this is correct then you likely have a POST problem (Power On Self Test), the beep you normally hear is conformation that the computer has passed the POST correctly - if you no longer have the POST beep then I suggest you look up your motherboard manual for more info but the basic check is to confirm all the cables and drives are well connected, the RAM is fully and correctly inserted. If you have recently added any new devices to your computer (graphics card or RAM etc) then remove this and see if the POST problem goes away. You may also find in your motherboard manual something labeled CMOS Clear - this will be a jumper (little pins sticking out) of the motherboard which is essentially a reset for the BIOS which may help rule out an issue in the BIOS config.
Nov 24, 2013 | HP Pavilion Computers & Internet
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 2400 won't turn off but goes off/on
The diagnostic code that you have specified is a memory related issue please try reseating the memory or swapping with a known good compatible memory stick in adverse case it can be the motherboard as you have specified that A & C take turn being yellow and green.
for more instructions please click here to got to a wizard which guides you through the step by step troubleshooting
Feb 19, 2009 | Dell Dimension 2400 PC Desktop
HP C4180 orange light
your cartage is now damage relapse it your problem will be solved
Dec 17, 2008 | HP Photosmart 4180 All-in-One Printer
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
I moved my computer to another room and now the monitor won't work. When I turn the computer on, the light turns green on the monitor for about 2 seconds then goes to orange and the screen stays black. If...
Make sure you don't have two video cards on your machine and have plugged into the wrong one.
Failing that, open the case and make sure the card is plugged firmly in its slot (do this with the power off).
Sep 29, 2008 | Computers & Internet
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 3000 PC Desktop Logo
117 people viewed this question
Alun Cox
