Question about Garden
The steering wheel on my toro lawn tractor is loose - teeth won't engage. It doesn't look like the teeth are broken - can I loosen the plate on the tractor that is attached to the wheels and adjust to fit into the cog on the steering wheel column
    Sergeant:
    Champion:
  • 226 Answers
No; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Posted on Jul 29, 2009
Why does steering slip turning left?
broken teeth on the steering gear (attached to the steering rod) or the steering plate (the one that turns the wheels) follow the steering rod from the steering wheel down to the frame, if it goes THRU the frame look underneath the lawnmower and youll see which one is messed up, just replace the one that has the broken/worn down teeth, hope this helps
Jun 02, 2015 | John Deere Garden
Blades will not engage on toro LX426 Lawn Tractor
Either The drive belt for the blades has come off, or it has broken.
Jul 03, 2014 | Toro Lawn Mower With Toro Power Tools
Craftsman dgt 4000
Broken gear at the end of the steering linkage, or broken teeth, also check to see if the stationary gear mounted to the tractor itself isn't broken off or worn out.
Jun 08, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Toro personal pace mower. Model 20017 The propulsion system isn't working. If I lift the mower, the wheels will spin, but back on the ground it won't propell the mower. I just put a new...
im assuming you dont here any grinding, start by tightening the cable ( loosen the cable mounting bolt slide the cable towards the engine, make sure you leave some play in the cable so its doesnt engage constantly and re-tighten ) this is most likely your issue however if you re-test and get grinding you either need new drive gears and wheels, new transmission or possibly both, you said it does something just not powerfully this pretty much rules out your belt, highly doubtful its that worn out and if it came off of a pulley it would do literally nothing, however if you tighten it and the drive is almost normal but still weak you do have a worn drive belt
May 10, 2011 | Toro Power Lawn Mower
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Front drive wheels won't engage
Is it possible that the belt has either broken or come off the pulleys? Next step would be to remove the cover and see if there is something preventing engagement or if you see any broken parts. May even be as simple as lubricating the cable/levers.
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
My toro recyclers self propel drive wont engage. belt and pully run and turn but wheels wont.is it the gearbox itself??
most likley it is the gear box has failed but first take one of the wheels of to make sure that the plastic teeth on the weels didnt go bad (unlikley but wishfull thinking)
Jul 11, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,011 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
