Question about Nintendo DSi Blue Console
DSi says that duplicate IP addresses exist and to check my DHCP settings
I got this same error using a Linksys WRT54GS.
On the basic setup page, under Network Setup>Network Address
Capture(lefemenu.dhcpserverset)Server Settings (DHCP), I changed the Starting IP Address from 192.168.1.100 to 192.168.1.110 and amazingly it worked.
Posted on Sep 20, 2009
Someones using ur ip or your registered under another dsi for that ip
Posted on Jul 27, 2009
How to install router wr740n v4 without resource cd
Milan have you got the user manual as it clearly explains how to set up the router and configure it manually !
http://www.tp-link.com.au/resources/document/TL-WR740N_V5_User_Guide.pdf
Your modem device already on your network has to have an IP address of 192.168.0.1 and according to the user manual the router detects the conflict in ip address and allocates its IP address as 192.168.1.1. If you IP address is different say 10.0.0.1 then you will have to plug just the router in to your Laptop and alter the i/IP address to 10.0.0.2 and turn off the DHCP server if the modem or existing router has DHCP. You will need to alter any existing DHCP server to have the first 10 IP addresses skipped for available leases to the computers.
Feb 07, 2015 | TP-LINK TL-WR740N Router
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
When changing IP address the Computer has access to the internet, why IP given is NOT going to the internet
It may be use already. Especially if on DHCP. ipconfig /renew is the command. The IP does not matter as long as it works.
Duplicate if static.
Mar 25, 2013 | Dell PowerEdge Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Someone else is using my ip adress
it is possible that your router gave out a duplicate ip address or that your using a static address and the router is giving the ip address you are using to another computer.
please check that your computer is setup to DHCP or that the other device/laptop/pc is set to dhcp or obtain dynamic ip address.
Sep 26, 2011 | Toshiba Satellite P105-S6197 Laptop
NEED HELP TO SETUP MY TRUEMOBILE 2300 ROUTER TO MY DELL LATITUDE D600 LAPTOP. I HAVE BEEN TRYING TO GET WIRELESS CONNECTION. WHAT I DO HAVE , 1300 TRUEMOBILE PC CARD PLUG IN. WHAT I DON'T HAVE IS A...
The Network Key you're probably asking for is on a sticker located, underneath the router. Can you check?
Here's a way to configure your router for your existing network (assuming you already have one) :
If you have an existing network, chances are you have already configured network services on the network. In this case, you would use the router as a pure Access Point to extend the range of your network by allowing more attachment of wireless and wired computers. You MUST also turn off the DHCP server on the router if there is a DHCP server running to avoid IP address conflict.
To configure the router as an Access Point with the DHCP server disabled:
  1. Open your web browser and go to http://my.router, (or the default address http://192.168.2.1.)
  2. Click the Basic Settings tab on the top navigation bar.
  3. Select Access Point Mode.
  4. Click the Next button.
  5. Click OK to dismiss the DHCP disabled message box (The DHCP server will be disabled in Access Point Mode by default).
  6. Click the Advanced Settings tab on the top navigation bar.
  7. Click the Advanced IP Settings tab on the left navigation bar.
  8. Assign an IP address to the Wireless Broadband Router.
    note.gif NOTE: The IP address should be reserved by the DHCP server. The Wireless Broadband Router cannot act as a DHCP client, therefore, it needs a static IP address for its LAN interface.
  9. Click the Submit button.
  10. Click the Save & Restart button.
  11. Note the status bar at the bottom of the screen.
  12. While the Wireless Broadband Router resets, the Power light on the front of the unit blinks.
  13. When your web browser returns to the main page of the Wireless Broadband Route, the device has successfully restarted with the new settings.
    note.gif NOTE: The main page may not return if you have changed IP address of the router in Step 8. To view the main page, type the new IP address of the router in the web browser to access it.
  14. Plug an Ethernet cable from the existing local network into any LAN port on the Wireless Broadband Router.
Jul 01, 2011 | Dell TrueMobile 2300 Wireless Router...
Unable to obtain ip address
With this problem it is most likely to be the ds its self. This is because the ds lite only takes WEP internet security were yours maybe have a WPA / WPA 2 which does not work on a ds only a dsi. So it can't get your ip address
May 05, 2011 | Nintendo DS Lite Console
How do i manually configure and ip address for the mitel 5224 ip phone?
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Feb 10, 2011 | Mitel 5224 IP Phone
How can i obtain my ip address
On the DSi's main menu, you should be able to scroll to an option that contains the settings. One of the buttons on this page will allow you to see information about your DSi, including the MAC/IP address (but unless the IP is static, youll be set to DHCP.)
1. From the Nintendo DSi Menu, select System Settings.
2. Scroll over to page 3 of the System Settings.
3. Select Internet.
4. Select System Information.
The IP Address should be on the screen that appears.
Dec 20, 2010 | Nintendo DSi Blue Console
Nintendo DSi Blue Console Logo
1,332 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
