Fills with water the drum turnes a few times then stoppes
    Top Expert:
  • Washing Mach... Master
  • 78,919 Answers
SOUNDS LIKE THE WASHER TRANSMISSION HAS FAILED OR THE MOTOR THAT DRIVES IT HAS FAILED.
Posted on Jul 27, 2009
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Water continues to fill into the washer drum on the spin cycle.
Hi
You could have a stuck solenoid valve
Try this: Set the water temp on cold. Turn on only the hot water.
Does hot water try and fill the drum?
If so then there is a problem with the hot solenoid.
Next set the water on hot. Turn on only the cold water. Does cold water try and fill the drum ?
If so then there is a problem with the cold solenoid.
Jan 05, 2011 | Whirlpool LTE6234D Top Load Stacked...
Washer does not fill with water but motor continues to turns drum
Yes the drum will always spin when filling it is called stirring, however, you will find you need to replace the (I assume) cold inlet valve, or you could put the cold hose on the hot valve and do a hot wash, this means it would fill with cold water, however some machines do have a sensor for sensing water temp, if this is so the machine will beep, and it may take some time to fill. :)
Dec 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
New washer, seems to work fine. I just question the water filling sequence at start of a wash. The water valve opens in 1 sec spurts about 6 times when drum is rotating in one direction. On 7th time it...
Every few months, new things are done to improve washing methods. If washing machine is washing clothing cleanly, and no apparant fault code comes up, then it is how the controller is programmed and meant to be.
Aug 14, 2010 | LG Washing Machines
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Aug 21, 2009 | Candy Washing Machines
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Drying cycle ma;function
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Oct 21, 2007 | Bosch WFL 2063 Front Load Washer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
