Question about GPS
Cannot enter new address/system stays on present address entered from address of previous destinations 2005 cadillac dts
  • 3 more comments
  • normanwade23 Jul 28, 2009
    THE GPS ALWAYS WORK PERFECTLY. IT IS A BUILTIN UNIT CAME WITH THE CAR. WHEN I PUS ADDRESS BUTTON ON THE DESTINATION SCREEN IT WON'T GO TO THE ADDRESS SCREEN. BUT IT WILL GO TO PREVIOUS ADDRESS SCREEN WHERE AN ADDRESS IS ALREADY ENTERED.
    I ONLY ENTERED ONE ADDRESS FROM PREVIOUS DESTINATION SCREEN NOW IT WON'T CLEAR OUT FOR A NEW DESTINATION. CANCEL SCREEN IN GREY NOY BLUE THEREFORE I CAN NOT CANCEL ROUTE
    THANKS, I DID CALL MY DEALER AND WAS TOLD TO BRING THE CAR IN. IF I LEARN HOW TO RESET IT I WILL LET YOU KNOW. I DID TRY TO GO BACK TO DEFAULT SETTING BUT NOTHING CHANGED.
    no thanks i am going to my dealer
  • normanwade23 Jul 29, 2009
    THANKS FOR THE INFO MY UNIT WAS PUT IN BY THE MANUFACTURER. IT CAME IN THE CAR. I HAVE DECIDED TO TAKE IT TO THE DEALER
    Brigadier General:
  • 4,090 Answers
This is not quite a clear explanation But i will take a hit on it and see if we can get this right for you.
When you select a new destination and select GO the unit loads a map of a place that you see regularly on the screen.. like a default.. say NY City it remains on screen without ever changing to your true location say Ontario and then starting to give you instructions to proceed tpo the selecfted destination?
Firtsly you can set your STATE of origin in settings
However that can become lost if the unit loses all battery power or is turned off completely, so its sotrt of a waste of time unless u keep it cxharged up all the time.
Now to what may be the cause of it NOT going to the selected address.
!st Check that the PORT and BAUD rate are set in settings correctly, consult the manual for this or use the autoconnect option in Satellites
2) the battery power is LOW and therefore cannot connect.
3)( you are in a location where a fix cannot be effected.l Take it outside, even out of the car and try it Some connections can take upo to 9 minutes as it accesses 4 satellites to get a true triangulation.
If none of the above work the news may be really bad. Your SIIRF chip is damaged and is costly to effect a repair. Cheaper to quit and buy a new unit.
TIP. Never start the car with the GPS plugged in to car power Always connect after engine start.
Posted on Jul 28, 2009
  • dennis bullard Jul 30, 2009
    It would have been more helpful to say that this gps is hard wired in the car and not just have the assisting people assume it is a standard GPs that is portable.
    The type of GPS that are hard wired are quite different in the problems they present.
    They are usually also part of a service agreement after installation with the suppying installers.
    Your request showed no brand and gave minimal information to help the tech to provide you with information that would generally cover the problems experienced with GPS units
    I think you were given a good all round response to the sketchy request you made
    Now taking it to the people who installed it after receiving help is someewhat cheeky. Why not do that in the first place as it is covered by a warranty!
    Dennis
    President:
  • 2,777 Answers
This is the built in GPS unit that your car came with correct? Not a detachable unit? Also, when you have put in addresses in the past has it worked just fine? It sounds like it is putting the address is as the next address, meaning once you get to the address in the GPS it may kick over to the next address, but you may have left the current address and thus it's not taking the new one. There is a way to fix this.
Please let me know what kind of GPS it is for sure and I will help you out here.
Thanks
T
Posted on Jul 27, 2009
  • 1 more comment
  • Tim Grayson
    Tim Grayson Jul 28, 2009
    Sounds like you will need the unit reset, to my knowledge only a dealer can do this. Check your manual to be sure, but it is definitely a software malfunction if it used to work fine. I am still researching this on my end. Let me know if you find anything.
    Thanks
  • Tim Grayson
    Sounds like the issue is getting worse. If anything give your local Caddy dealer a call and see if they can tell you how to reset that particular unit. I am trying to find this info now, but a dealer will know right away.
  • Tim Grayson
    Ok sounds good, let me know what you find.
    Thanks
How to enter frequent destinations onto my favorites list
if you enter a destination, you should then be able to go to settings, click on settings and go to favorites, then you should be able to select add and then you can pick from destinations you have previously entered, you should then even be able to give it a name
Sep 09, 2014 | Tomtom GPS
HOW DO I DELETE ADRESSES FROM BINATONE G350 SAT NAV
You can only delete the Recent Destinations and destinations in the Address Book, the Sat Nav will still store destinations you have entered and as new ones are entered the older ones will fall off the system when maximum is reached.
Apr 03, 2011 | Toymax Binatone Carrera X350 Car GPS...
NEED INSTRUCTIONS
Access the web-site: http://maps.google.com
Enter the address of your intended destination, and do the search.
Then, click the "directions" button, and enter your current address, and submit it.
You will get INSTRUCTIONS on how to drive/bus/walk from your current address to your destination.
Nov 17, 2010 | Computers & Internet
I need to change voice mail box,, so when a message is left, it calls my cell,, the present ox is calling a previous employeee.. HELP!!
To change your pager notification number, access your voice mailbox, press the admin soft key or 8, then press 6 to open the off prem. message notification, press the admin soft key or 1, choose the type of destination (phone, extension, or pager), press the Chng key to change the destination number, enter in the new telephone number and press the ok soft key.
Sep 03, 2010 | NorStar M7310 Corded Phone
Why does my gps ask me if I want to continue to my final destination via the address I just entered?
This usually occurs if you enter a second destination after you entered the first. For instance, if you press "Home" on the unit, and then manually enter a second destination, it will ask if you want to go to the second destination via Home. This is a nice feature if you are stopping briefly at one place, and then going on to the second destination.
Oct 11, 2009 | Garmin StreetPilot c550 GPS Receiver
All of my Nuvi 200 settings (recently accessed, favorites, etc.) suddenly disappeared. When I entered a new destination address, however, it still worked. What would erase my previous settings?
I can help you fix your Garmin Nuvi 200W.
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 ...enter a Start and End destination!
Yes, you can enter in a specific address as follows:
Press "Where to"
Press "Address"
Select State
Spell City
Enter House Number
Enter Street
Press Save
Press Go
If your Nuvi has acquired a satellite lock, you will then be ready to go.
- Jim
Nov 29, 2008 | Garmin nuvi 200W GPS Receiver
Removing previous destination
I hit Guan by mistake but meant to enter new york. How can I change it to new york?
Dec 26, 2007 | Tomtom ONE GPS Receiver
Magellan Roadmate 360 reset
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
GPS Logo
44 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
