Question about Cuisinart DGB-500 Coffee Maker
Because the tracks get gummy from coffee, the filter basket door sticks. Trying to pry it open, I broke the bottom corner of the cover. Cuisinart does not sell replacements for this - Does anyone have an old coffeemaker they want to sell that part to me? It is a DGB 500, black. Any color will do at this point... Thanks!
    Champion:
  • 363 Answers
Check appliancefactoryparts.com or appliancefactorypro.com
Posted on Jul 28, 2009
Cuisinart DGB900BCC coffee machine. Problem is after machine grinds coffee it starts making clicking and beeping sounds and won't brew coffee. I've cleaned it completely and open and shut door several...
I've solved my problem. Called Cuisinart customer service and spoke with a rep. The filter basket must be aligned. Shouldn't push down when putting basket into position. Also, cleaning underneath the bean grinder with pipe cleaner helped.
Dec 29, 2009 | Cuisinart Coffee Makers & Espresso...
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
The coffee maker prematurely turns off at
Hello 1pro8vo2,
This is a common problem with Cuisinarts and is fixable.
I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
Jul 11, 2009 | Cuisinart Coffee Makers & Espresso...
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Replace the spring that holds the basket door closed
The spring can be replaced if you can get a new one - however it does take a lot of patience to get it aligned properly. I have purposely disassembled my 500 to clean out the tracks and basket latch and have successfully reassembled. In fact, right now I'm waiting for the coffee to finish to enjoy a fresh cup (although, all be told, at this point I'd rather go grab a beer! ;-) ) The trick with replacing the spring is that it has two different ends - one with a hook that is horizontal to the coil of the spring; the other hook perpendicular to the coil. The horizontal hook goes around the back peg of the latch lever, with this leg being against the bottom side of the lever. The other hook is used to maintain the tension and is placed against the side body of the sliding shelf. When placing the spring into place the angle of separation between the two legs is approximately 15 degrees - note: the legs do NOT overlap (ie, go past each other - they maintain their respective sides). The trick that I learned was to continue to apply downward force on the latch lever, thus forcing the retension peg to be as fully exposed as possible. This reduces the very frustrating occurrence of the spring slipping off the peg when you try to reinstall the cover. BTW, we've had this grinder/brewer for many years and thoroughly enjoy it - except for when the tracks gunk up & the basket spits out in the middle of brewing.....
Jul 10, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Filter Basket door sticking/ opening during brew
try this site [ nelson appliance dot com] they have parts for just about any kitchen appliance. they may have an exploded diagram for it or can steer you in the right direction for one. try the cuisinart site. cuisinart is in champlain ny.
Sep 04, 2007 | Cuisinart DGB-500 Coffee Maker
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
184 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
