Question about Whirlpool Washing Machines
Washer leaks water from underneath - Whirlpool Washing Machines
  • 29 Answers
Most likely you'll have to replace the water pump $55 you can take it out and refill with water and slowly turn the pulley to see if it is leaking if so it will be coming out of the pulley seal don't try to rebuild pump it's not worth it. Before you do that take the front panel off and look for the leak when the machine in running be sure not to touch any moving parts or any electrical parts. leaks may come from inlet valve, pump, hoses or spilling over the edge of the tub.
Posted on Jul 28, 2009
Water underneath unit?
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
My washer is leaking from underneath the machine. What is the cause?
It could be a few things, a hosehas a hole in it, the water pump is leaking , or the cenbter seal on the transmission is leaking. Best way to check is to put some water in it, have someone help you lean it back and look underneath to locate the leak. If the water is leaking only in the agitate cycle and not as its filling then its your center seal.
Nov 03, 2010 | Kenmore 23822 Top Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
There is a little bit ofwater leaking from underneath the washer.
The bolts on the drum case are probably loose.
Remove the rear cover to access to bolts
Jun 23, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer is leaking water from underneath. How can I fix this problem
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Mar 07, 2009 | Roper RAS8244KQ Top Load Washer
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
