Question about Maytag Neptune FAV6800AW Top Load Washer
Washing machine water leaking onto the floor during wash cycle and rinse cycle?
  • Anonymous Mar 22, 2014
    During wash cycle water leaks from underneath
  • 96 Answers
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Posted on Feb 26, 2008
2 Suggested Answers
  • 246 Answers
SOURCE: During wash cycle, my washing machine has started leaking
Check your hoses, supply, drain. for cracks or loose fitting, clamps.
Posted on Dec 30, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Water is leaking onto floor during filling and also during the rinse cycle.
you will have to check the hoses coming from the water inlet solinoids as it sounds as if there is a leak in one of them.
Jul 27, 2011 | Kenmore 23822 Top Load Washer
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer isn't holding water to wash on the begining of the cycle or on Rinse. Any ideas on how to fix it?
If you mean the water runs or drains out during the cycle, the drain hose is too low. It should be as high as the top of the machine. If you mean the water leaks out onto the floor, then it could be a hose has a hole, or the pump is leaking.
Jan 28, 2010 | Whirlpool Washing Machines
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
Sep 14, 2008 | Whirlpool WTW6400SW Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
349 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
