Question about Toshiba Satellite A135-S2276 Notebook
When i put in the charger at anytime the laptop freezes
  • 4 Answers
Try powering it on with the ac with out the batterie in the laptop to see if it boots if not then you are looking at a mother board replacement
Posted on Jul 27, 2009
HP Pavilion DV7 freezing during charging
When your laptop goes on battery power the processor automatically gears down to conserve battery power, but when charger is used the processor goes to full power and you run heavy programs drawing more resources, I suggest you upgrade your ram because heavy gaming uses more ram memory.
Jul 04, 2012 | Computers & Internet
Tip
T60 IBM laptop keyboard pointer - touchpad. REMOVE the BAD Battery
I was looking here for a solid answer for Why my T60 IBM laptop was freezing up ( anytime I touched the pad or the pointer on the keyboard )
And I found that with the battery removed And the A'C charger plugged in, my problem was fixed. The battery was not any good ...
I wanted to share that - as I had done every conceivable thing as far as upgrades and had no luck until now. It worked.
on Jan 25, 2012 | IBM Computers & Internet
Dv6-1251nr freezes
mother board issues 101 hope it's got data backed up
Jun 20, 2012 | HP Computers & Internet
Good day mam/sir can anyone help me with my laptop. when i start my computer and i put in the charger the laptop will crash. but if i charged my laptop with the same charger, and use it without the charger...
The most likely cause is a bloated registry which has become the home for all kinds of useless bits and pieces of data. Whenever any change is made to the system settings or a program is installed or uninstalled, a new entry is generated in the registry. The operating system while running your computer has to pick its way through all this excess material. There is a multitude of useless bits and pieces to be removed.Parts of uninstalled programs,parts of incompletely installed programs,dead drivers and many other things. clean your registry and remove all the useless data fragments and no longer needed information to fix the freeze error! I should like to commend Registry Easy http://cleanup-comuter-run-perfectly.com to you ! You can try ! Good luck!
May 03, 2011 | Toshiba Computers & Internet
Toshiba A205-S4607 freezes immediately charger is plugged in
It might be the battery,which is causing this problem.Try cleaning the contacts on the battery with a old toothbrush,also the contacts on the computer aswell.
Good luck
Sep 14, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Asus pro50g keeps on freezing anytime on my
remove the battery. then power on using power adapter.
Aug 23, 2009 | ASUS Computers & Internet
When i log onto my LG notebook x120, it freezes. it takes some time for the mouse to freeze, but the rest of the programs are frozen.
If this happens almost immediately when logging on to Windows, it can mean one thing.
Usually a freezing is related to the battery, charger, or anything electrical. First, try to remove the battery and run the laptop solely on the charger.
If this doesn't work, then check the charger to make sure the voltage and amperage is correct.
If they are, then the problem is internal and you will need to get it serviced.
Aug 09, 2009 | LG X-Note LM50 Notebook
Laptop freezing.
Most likely need to do a complete system reboot, or run a program that cleans up the system, sounds like a regestry issue with the operating system, if you're not savvy with operating system fixes, then I would suggest taking to a shop..
Mar 09, 2009 | HP Compaq nc6000 Notebook
Laptop freeze when in ac charger
You really should have a cheap multimeter to help in this case.
There are three possible failures; the new battery pack has a shorted cell, the charger is defective or a regulator internal to the laptop is failing.
With meter, you can check two of the three areas; the battery pack and the charger. Depending on which kind of batteries are used in the pack, if it is charged, you can determine if it is completely functional by checking contacts on the case of the pack. The most common type of battery used is the nickle-metal hydride type (NiMH) which has a nominal voltage of ~1.2 volts.  If the pack is rated 6 volts, you could measure either 4.8, 6 or 7.2 volts with the last one the most likely. If it measures 4.8 or 6 volts, it probably has one or two cells shorted, making it useless.
The charger could measure all over the map; many of them are unregulated and if they are rated at (for example) 9 volts, they could easily put out 14-20 volts when they do not have a load on them.
If those two items seem to check out OK, then the regulator in the system has gone bad. This might be on a separate board inside but to check it out, you really need some technical experience, otherwise you don't really know what you are seeing or looking for.
Sep 23, 2008 | Dell Inspiron 5150 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
