My remote has been damaged, where can I find another one
    President:
  • 1,124 Answers
You can get a universal remote that will program to your tv from WalMart or any other general electronics store..
Just follow the directions that come with it to program the remote to work for your tv..
Posted on Jul 27, 2009
Remote control does not respond
If the case is not damaged, remove and re install the batteries. That generally fixes problems like this. If not you will have to replace it.
Dec 25, 2013 | Hampton Bay 52 In. White Redington...
Philips mms 5.500i
My philips mms 5.500i remote is damage pls tell me how & where we buy new remote
Sep 13, 2013 | Audio Players & Recorders
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Remote control doesn't work. Can't do any operation from a remote control.
remote control have a less chance of damage. It is mainly damage by physically only... check out at battery region, is there any puff out..
observe by inserting battery whether a burning smell comes or not..
Mostly this problems occur in remote..
BETTER IF YOU GO TO YOUR NEAR ELECTRIC SERVES CENTER.. ; )
Oct 08, 2010 | Toto NEOREST 500 HIGH PERFORMANCE ONE...
TV is not atrting with remote
Hello
I think the first thing you need to do is to check the battery in the remote if its damaged or not.
If it is damaged you would have to change the battery for the remote to work.
If it doesn't work then you can try to go out to any television store to get a remote that is compartible with your Television and i bet your problem would be solved.
Aug 05, 2010 | Prima C2012 TV
My remote control on my electown television was damaged
go to deeco building located at raon st. sta.cruz manila..they sell original electown remote control. I know because we have exactly the same problem..
Apr 04, 2010 | Televison & Video
Remote is damaged so unusable, but alarm will go off in the driveway in the middle of the day for no reason....any explanation?
When you say remote is damaged??? How is it damaged?? If it has gotten really wet or broken it is possible that if near the car meaning close enought the remote could be activating the alarm itself. Some of those remotes have a panic button on them and or can act as panic by holding two button same time
Oct 15, 2009 | 1999 Mercury Grand Marquis
Milk spilled on tv remote controller
Remove batteries from remote, to avoid further damage caused from liquid on powered circuits.
Allow the remote with the cover opened to dry for few days. Ideally the remote should be disassembled and the internal parts treated with cleaning solution, or 70% isopropyl alcohol and water. If you do not want to disassemble just let it there to dry up.
If the remote does not work after that , it means that the liquid had damaged circuits.
In that case get a replacement remote.
Replacement Remotes
1-800-Remotes
TV Remote Controls - UK Replacement Remote
Aug 26, 2009 | Televison & Video
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Feb 04, 2008 | Yamaha RX-V800 Receiver
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
