Question about Sony KV-27S42 27" TV
Blank screen with sound
My Sony KV-27S42 has a blank screen but the audio come through fine. I do get an image when running through a VCR.
  • 281 Answers
Re: Blank screen with sound
I guess you mean RF input for the dish, then the problem is with the tuner section. Try replacing the tuner, it is not so costly.
Posted on Jan 18, 2008
0 characters
3 Points
Sony kv-27s42 no picture no sound can here relay click
I will look up your specific model to be sure, but teh 3 blinks usually mean a power supply problem. Stay tuned for more...
Aug 23, 2008 | Sony KV-27S42 27" TV
Sony KV-27S42 no sound and audio blinks four times
+13 & -13 requires for Vertical Deflection IC and produced by Flyback Transformer, these volts will be produced IF Horizontal deflection circuit works properly. so try to check H-Out Transistor and its necessary volts / signal. Pls also mention correct Model Number to provide you more help.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Thermistor resistance value on Sony KV-27S42
180358641 is correct replacement of THP601, Schematic (Service Manaul) is available on charge basis, have nice day!
Aug 01, 2008 | Sony KV-27S42 27" TV
Sony KV-27S42 27" TV Problem
Hello BrianMcL
You are 100% correct, you will need a degaussing coil to take care of this problem. The instructions on how to use it will be included with the degaussing coil.
I hope this helps,
Thank you,
Jul 06, 2008 | Sony KV-27S42 27" TV
SONY KV-1970M3
Have you check all the Cap at the Vertical and Horizontal block ?! and near the PSU ???
Feb 22, 2008 | Sony KV-27S42 27" TV
Won't turn on - comes on and goes right back off
Is the picture good or is it dull and dark?
A dull aka weak picture tube will cause low beam current and blank the screen. Last set I had do this I turned up the screen control to make it brighter. Use caution and don't turn it up too high were you see vertical retrace lines in the picture.
Sony KV-27S42
If the screen won't come on then the diagnostic will never show. The 4 blinks is an error code. If the set is older than 12 years then it doesn't owe you anything, you got your money's worth out of it. Average life of any tv from that genre is 8-12 years. It's time for a new set, or take it in for an expensive repair ( pending parts availability).
Feb 10, 2008 | Sony KV-27S42 27" TV
Sony KV-27S42 Television won't turn on
NO -the tube will be fine . The TV is in 'protect mode' . THis means that it has shutdown because of an internal fault condition. THis TV needs a technician's love..
Sep 17, 2007 | Sony KV-27S42 27" TV
Picture doesn't come on
Is your screen black? If so then you may have a bad picture tube. I've seen this problem several times with SONYS. The thing seems to just open up and quit working.
Jan 09, 2007 | Sony KV-27S42 27" TV
Sony KV-27S42 27" TV Logo
62 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
