Question about OEM Systems Car Audio & Video
2005 gmc will not eject the cd - OEM Systems Car Audio & Video
Cd does not eject
remove radio. take to radio repair shop.
Jan 16, 2014 | 2005 GMC Envoy
Removing a stuck Cd from car factory stereo
There is no "standard proceedure" for this. The last time I had one of these it was because of a defective eject switch in the CD player. I removed the unit and took it to an electronics repair shop, where the technician disassembled the unit to get the CD out and replaced the eject switch.
Jun 16, 2012 | 2005 Chevrolet Silverado
CD will not go in automatically if I push it in cannot eject
cd mechanism is no good and need to be changed. this repair is common for these vehicles. I suggest that you find a used stereo for that truck and if you have a mechanical ability, switch the cd mechanisms over. Another factory stereo cannot be replaced into the truck unless the computer systems are recalibrated. so it will save you time and money to just reuse your old stereo be just replace the cd mechanism
Aug 06, 2011 | 2005 GMC Sierra
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
CD STUCK IN RADIO
hi..
there is a motor and belt driven mechanism for ejecting and inserting the disc.the belt mecahnism might have damaged so it is not letting it to eject the CD.serivice it and they wil replace the belt.
Jul 13, 2010 | 2005 GMC Sierra
Cd not ajection
Welcome to the world of gm delco radios. I am a used car dealer in Canada and I deal mostly in trucks and suv's. Honestly I'd say 75% of the radios in Gm's don't work properly, the loading mechanism gets jammed when you try to eject and "check CD" appears. Unfortunately it's not the CD, and to save yourself any further heartbreak, rip the player out and get yourself a good quality Kenwood or the likes.
Jun 12, 2009 | 2004 GMC Envoy
CD player won't work
it may have another stuck CD inside. or something else. Especially if there are kids around. I removed 2 CD's from a stereo which had the same problem.
Apr 08, 2009 | 2004 GMC Sierra 2500
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
Car Audio & Video Logo
118 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
