Question about Sega Sports Worldwide Soccer for Sega Saturn
I need to know how to reset the factory alarm in my 04 saturn vue the alarmi has been tripped? and it wont allow my car to start so a mechanic told me to manually reset the alarm but i dont have my manual. other than not starting all the interior lights flash when i try and start the car
  • 4 Answers
Try disconnecting the batterie the red cable and let it set for about 5 min then connect the batterie and try it then
Posted on Jul 27, 2009
My vue wont start and the battery is good and my alarm system wont stop beeping unless i disconnect the battery
My vue wont start and the battery is good and my alarm system wont stop...
get your car fix right now
Feb 28, 2016 | 2006 Saturn Vue
Keyless fob lock out
Alarm System Operation & Diagnosis - Range Rovers
www.rangerovers.net/repairdetails/becm/alarm.html
(If done by the key, a press on the remote locking button is still required before .... the BeCM goes into a 10 minute lockout mode (30 minutes for 1996 and later ..... buttons at the dealership, you may need to reset the code on the fob - which is ...
How to reset the security lockout on a Saturn Vue
www.kittycatonline.com/.../How-to-reset-the-security-lockout-on-a-Satur...
Nov 30, 2014 - How to reset the security lockout on a Saturn Vue. ... Now, though, not only does the "phone start" system still fail to function, the remote start fob now fails to work as well. ... the Passlock system starts out in what I'll call "agressive" mode. ... basically disabling it: Get the original factory remote unlock key fob, ...
Jan 08, 2016 | Cars & Trucks
My 04 Saturn Vue's emergency break light is always on, could this be a fuse?
Do you mean the Brake lights showing at the rear of the vehicle? If so this is the brake light switch located at the brake pedal....either broken or needs adjusting!
Jan 02, 2015 | 2004 Saturn VUE
How do I turn my alarm on the saturn vue
If you have a factory installed alarm the original factory key can activate the alarm by pressing the lock button twice(rapidly). The lock symbol is generally a symbol of a "locked" lock.
If there is no buttons on the car key or it is an aftermarket alarm, a key fab (a little alarm remote control with 2-4 buttons the size of a keychain) is needed to activate/deactivate the alarm.
May 09, 2012 | 2007 Saturn VUE Green Line
My back door on my 04 Vue will not unlock, so there fore I can't open it; there is no key hole so everything is operated from my key fob. What can I do to open or unlock the door.
had this problem twice now you need to replace the whole door handle mechanism within the door its around 200. saturn vues are junk!!!
Feb 21, 2011 | 2004 Saturn VUE
When I try to start my 2003 saturn vue the key is hard to turn unless I push brake very hard and turn the steering wheel. What's the problem?
My 2004 Saturn Vue had the same problem. I thought the ignition had to be changed and I drove the Vue a long time with the key hard to turn and pushing it in before turning it. I mentioned it to a Saturn Dealer mechanic while having warranty work done. He told me a new key had to be made using the key code (located on the inside panel on the driver door). They made it and it totally fixed the problem. I think any GM dealer can do that for you.
Jul 03, 2010 | 2004 Saturn VUE
Front end rattles on rough road-told by certified mechanic that this was normal for this model and to fix would require replacing the whole steering column/power steering box
your mechanic is an idiot if he calls a rattle normal. see service bulletin 04-02-35-006 the dealer can look at your car and see if it applies.
Sep 24, 2009 | 2003 Saturn VUE
04 Saturn Vue Temp Gauge
check out rockauto.com i have found most all parts for my saturn vue 04 v6 3.5l fi. go to the parts catalog and select ur year, make, model, and engine.
Sep 10, 2009 | 2003 Saturn VUE
2003 Saturn Vue Alarm - Ignition Kill
Removing the battery cable is something the alarm companies no the theifs can do. Find the valet button, this along with a few steps that you can find with your alarm manual will reset the system.
May 16, 2009 | 2003 Saturn VUE
Cel on a 04 saturn vue
Disconnect your battery. touch the neg. and positive cables together for a second. let it sit for at least an hour. that should reset everything. as far as reading codes you would need a scanner. on OBD-1 cars you could use a paper clip and flash the codes. but on OBD-II you need a scanner
Jan 21, 2009 | 2004 Saturn VUE
Sega Sports Worldwide Soccer for Sega Saturn Logo
137 people viewed this question
Top Sega Sports Video Game Consoles & Games Experts
James Wishart
Are you a Sega Sports Video Game Console and Game Expert? Answer questions, earn points and help others
