Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Beater too low-will not lock
My kitchen aid is about 13 years old and now it is giving me trouble. It started throwing flour out of the bowl a few week ago. I looked at it and saw that the beater was touching the bottom of the bowl. I turned the screw a good half turn and that solved that problem but than the head would not lock with the beater adjusted. When I put it back to where the beater is touching it will lock. The beater is not just touching it is fully resting on the bottom of the bowl which makes the mixer wobble and make banging sounds. What should I do?
    Champion:
  • 363 Answers
I would check the bottom of the beater blades to see if they are out of shape.,or is the base of the mixer raised somehow to cause this problem
Posted on Jul 28, 2009
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
Aug 31, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen aid K5SS 300 w with NO beater to bowl adjustment screw. Is there anything else that can be done to adjust this?
There is an adjustment screw there. If you supply an email address I have the Kitchen Aid PDF on bowl adjustment for K5SS. My email address is screaming_skull@hotmail.com
May 02, 2014 | KitchenAid Food Mixers
Kitchen Aid stand mixer head doesn't lock down and wobbles
You need to do a couple of strokes with a rat tail file at a 30 degree angle at the top of the slot the head lock engages into. You will need to remove the hinge pin to do this. A Kitchen Aid agent will have done plenty of then so it won't cost an arm and a leg to get it sorted.
Nov 17, 2012 | KitchenAid KITCHEN AID 5 Quart Artisan...
I own a kitchen aid 6 qt stand mixer, if i have batter in the bowl the beater will stard to stick. It sounds like it will burn the motor out what can I do
Aren't you supposed to oil or flour it to stop that from hapenning? Just what I've seen my mom do. You are the cook.
Oct 18, 2009 | Food Mixers
The head to my kitchen aid mixer bounces up when kneading dough
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Apr 05, 2009 | KitchenAid Food Mixers
I have a kitchen aid stand mixer and the head jiggles when it is on and the entire unit "hops" and shakes at high speed. what's going on and how do i fix it?
Mar 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Food made with KitchenAid Stand mixer tastes like grease
The likelyhood of grease coming from the mixer is extremely small. As long as the beater & bowl were washed first and the shortening you used was fresh, there shouldn't be a grease taste.
Feb 17, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Beater rubbing bottom of bowl
Feb 14, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
224 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
